weight jacks or lowering springs ?
Old Jan 29, 2021 | 07:09 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
weight jacks or lowering springs ? what does everybody prefer ? pros an cons of both ...
Old Jan 29, 2021 | 08:01 AM
kaos420's Avatar
Car: 88 gta
Engine: 5.8
Axle/Gears: 3.73 POSI
Re: weight jacks or lowering springs ?
I have the eibach pro kit been on my car for 8 yrs no complaints.i will be switching over to weight jack system tho for the heavier spring rate an adjustability.
think they will help a lil more when auto crossing an doing track days.
Old Jan 29, 2021 | 08:16 AM
Abubaca's Avatar
Other than a little added cost, I can't see a drawback to using weight jacks over regular springs. You can adjust the weight jack obviously and with a regular spring you cannot. Whether it be for appearance or to fine tune the suspension for performance,
Old Jan 30, 2021 | 10:01 PM
88RS's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: lt1 10 bolt 3.23
I recommend not lowering it at all. These cars are long, and scrape enough at factory height going into driveways and parking lots. Just my and I'm admittedly uncool fwiw.
<-- that car isn't lowered.
Old Jan 31, 2021 | 12:36 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I don't know what it is about conventional springs but I can't keep my car on the road with them. It'll fishtail all over the place under power. It's crazy. Suspension Techniques, Hotchkis, Hypercoil. All out of control.
Set of constant rate weight jacks and the car goes straight as an arrow. Doesn't drag race worth a crap with those springs but it isn't trying to kill me either.
Old Feb 2, 2021 | 07:23 AM
UMI Sales's Avatar
Weight jacks have ease of ride height adjustability and also the potential to change spring rates outside even the manufacturers offerings. Most manufacturers tend to use industry standard spring sizes which means the common oval track warehouses have lots of options.
Standard lowering springs (like from UMI) have improved rates as compared to stock and usually lower a moderate, tasteful amount.
We sell around an equal amount of both.
Old Feb 2, 2021 | 08:49 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
,,,, and you can corner weight the car which is actually the intended purpose of weight jacks.
Old Feb 3, 2021 | 07:09 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
ill be ordering the umi weight jacks somtime this spring
Old Feb 3, 2021 | 10:43 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
To add to the Weight Jack option, you can assemble/fabricate weight jacks yourself to keep your costs lower and buy springs from a dirt track racing supply house where coil springs are more affordable than some of the usual suspect aftermarket parts suppiers, IE UMI, Ground Control,ect,ect….
Old Feb 3, 2021 | 11:31 AM
WTR388's Avatar
Car: 87 Trans Am
If I want weight jacks this is what I'll be doing... Some fabrication is required though.
Being in Canada, we get hosed on exchange rate, shipping and duties... I saved about $100 just by piecing together my own bump steer kit in comparison to buying the cheapest spohn kit... I'll probably save $400 building my own weight jack set up. Plus, I can borrow springs from my circle track friends to figure out a decent set up.
Old Feb 4, 2021 | 12:16 PM
91banditt2's Avatar
Engine: 5.7 HSR
I only used a couple bought items when I made my, rest was fabricated.
https://www.speedwaymotors.com/Weigh...late,6509.html
https://www.speedwaymotors.com/Repla...91645546-1.000
Old Feb 25, 2021 | 09:53 AM
chrias's Avatar
Air suspension
Old Mar 5, 2021 | 01:07 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
i dont have a garage i can fabricate in right now . i just got a corner i can build an engine in at my friends garage .
Old Apr 1, 2021 | 10:46 AM
y5e06's Avatar
Car: itsa '85 LG4 S/E Turd 'Bird
Engine: Wheezy 305
Axle/Gears: 10Bolt, 3.42s, TruTrac
came here for this.
i was thinking about doing this exact thing. I'll be pulling the engine in a few months and it would be a perfect time to do it. i know its been done before but i never paid attention.
I can fabricate plenty, but some clarifications:
did you mount the threaded plate in the spring upper location at the k-member?
Is there room for the jack bolt extending into the engine bay?
what part did you use for the spring bucket? Or, is there one that seems like it would be the best choice?
Global West sells a weight jack kit but it seems to mount at the bottom of the spring at the control arm.
Old Apr 1, 2021 | 11:09 AM
91banditt2's Avatar
Engine: 5.7 HSR
Originally Posted by y5e06
came here for this.
i didn’t think GW made weight jacks, didn’t see them on their website. I’m not aware of a style of weight jack that mounts on control arms.
I made the style like the UMI’s and the Ground Control’s where the weight jack sits in the K member spring pocket. The top larger cup rests in the Factory spring pocket and the lower smaller cup is where the shorter spring seats.
Search for member TEDSgrad he did a really good write on how to install weld in weight jacks
Old Apr 1, 2021 | 01:05 PM
y5e06's Avatar
Engine: Wheezy 305
thanks. for completeness, here is the thread i found as indicated above
https://www.thirdgen.org/forums/susp...g-vetruck.html
Old Apr 1, 2021 | 03:15 PM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
Did the same a while ago. Initially installed while everything was in place, then took the k member out for more work
Old Apr 5, 2021 | 09:15 AM
y5e06's Avatar
Engine: Wheezy 305
I'm about to pull the wheezy engine in about a month, so may just as well drop it out the bottom to get the k-member free and do this mod at the same time.
Anyone have weld-in weight jackers for the rear? Looking from below you can obviously see the spring location/pocket. but what is the composition of the structure above the pocket? Is it just a few layers of sheet metal? Easy enough to cut out and weld in like the front?
Old Apr 5, 2021 | 07:16 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Rears are easy. The hump in the spring pocket has a center hole. Pilot up through into the hatch area then open the holes with a hole saw. (Run it in reverse to cut a clean hole in the carpet). You can then just use a weight jack plate and nut with a couple heavy self tapping screws to hold it in place, dont need to weld it really. I ran that setup on my 92. Simple and cheap
Old May 9, 2021 | 11:58 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I'm confused, I see conventional and constant rate springs as being the same things. Just the addition of the weight jacks and their adjustment is what corrected your issue?
Old May 14, 2021 | 02:26 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
ok i dont have room running a 10.5 " rim an 285 tire up front
to use coilovers . so weight jacks it is .
Old May 23, 2021 | 07:21 AM
83 Crossfire TA's Avatar
Originally Posted by chrias
Air suspension
One of my least favorite answers. The way that most air suspensions are setup you have to soften (remove air) to lower the car, so as the car gets lower the spring rate goes down. The opposite of what you need/want in EVERY case except if you're doing it strictly for looks.
Are these mounted screw down so you adjust them from under the car through the control arms?
How did you get such clean cuts, was the tubing and flat pieces turned in a lathe?
Old May 24, 2021 | 07:16 AM
91banditt2's Avatar
Engine: 5.7 HSR
These were designed base off of the Ground Control WJ's that are adjusted through the bottom of the control arm. Here at work we have a machine shop in house so the parts that we fabricated were cut using a water jet, with the correct travel speed it can produce pretty smooth surfaces. The top portion that mates up with the K-member was cut from a 1 1/2" steel bar that took 2 hours to cut
kitt23
Jan 1, 2015 09:26 PM
micktroup2
Apr 23, 2010 08:55 PM
cam406406
Jan 18, 2007 06:48 PM
