Mounting a Quick performance 9" Ford rear on 87 Camaro
Old Jun 27, 2021 | 12:00 PM
jbander's Avatar
The mounting for the control arms on the axle has 4 hole , 4 mounting points, which one do I use for a stock configuration and what are the 4 different mountings for.
The axle is upside down/
Old Jun 27, 2021 | 05:01 PM
Re: Mounting a Quick performance 9" Ford rear on 87 Camaro
Those are like LCA relocation brackets that you could apply to a stock rear.
Best place to start is, where the rear end of the LCAs is JUST SLIGHTLY below the front (chassis) end. Something in the range of ½ to ¾" would be a great start point.
What you'll find is, if the rear (axle) bolt is too high, the car will wheel-hop ruthlessly, like stock, under acceleration. When the bolt is too low, it will hook up like pulling your teeth out under acceleration, but will wheel-hop unbelievably under braking (an OBVIOUS safety / life preservation malfunction). Ideal is where both are smooth and quiet, and present no problems.
Old Jun 27, 2021 | 09:00 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
'Wish I could afford one of those...
Old Jun 29, 2021 | 10:09 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I'm guessing you got a 9" because you got the power to use it (and broke your stock diff)
Most times you'll need to be in the lowest hole, if you got good tires
Old Jun 29, 2021 | 11:15 PM
jbander's Avatar
450+- and up to 250 shot . So after I hook up the shocks ,track bar,torque arm, stabilizer bar, with all that connected, can I change the mounting point of the LCA on the relocation bracket
Old Jun 30, 2021 | 03:52 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
yeah you can change it with everything else connected. I would do one side at a time though so the rear doesnt move too much on you.
Old Jun 30, 2021 | 05:08 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
With to Voice of PeeWee herman in the back ground yelling..."This Will Be Fun"
I love working on mine..putting it back together..My Radio station Plays that ..I have to giggle when I hear Pee Wee's voice..yelling that...as Im making something for the car..
Old Jun 30, 2021 | 10:13 AM
jbander's Avatar
Thanks for the help everyone!
jbander
Apr 28, 2021 09:59 PM
chopped31
May 27, 2007 12:55 PM
91NiteRida'
Dec 1, 2004 05:59 PM
89RsPower!
Jan 21, 2003 02:15 PM
BOTLFED
Oct 25, 2002 05:50 AM
