Knock in front suspension
Old Jan 14, 2023 | 07:17 PM
DGGM92Camaro's Avatar
Car: 1988 Camaro IROC-Z
Engine: 5.7 TPI
I have an 88 IROC and it has developed a loud knock noise that occurs usually when I go over a bump while turning. It is coming from the drivers front side wheel and today I lifted the car on jackstands to try and figure out the cause. It is supported by the torque boxes so the wheels were hanging free and off the ground. I grabbed the wheel at 3 and 9 oclock and shook it left to right. As soon as I did, I felt and heard a loud knock and said wheel dropped by about an inch. I have attached a photo of how it now sits. The car drives straight and the inside of both front tires wore out within a couple thousand miles. I am aware it needs an alignment but that is for when it gets back on the road. Any ideas what to check?
Old Jan 14, 2023 | 07:18 PM
Engine: 5.7 TPI
Re: Knock in front suspension
The front of the car is completely level, as you can see the left wheel sits significantly lower than the right wheel
Old Jan 14, 2023 | 08:08 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Well keep shaking it and look at what's moving.
Old Jan 14, 2023 | 09:00 PM
Engine: 5.7 TPI
Thats the thing, now that the wheel dropped down it doesnt move around or replicate symptoms outside a bit of play that occurs with both wheels and I can watch the steering wheel move in kind
Old Jan 14, 2023 | 10:33 PM
tajefe's Avatar
Maybe check your strut mounts
Old Jan 15, 2023 | 06:39 AM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
Maybe put the jack under the A frame. Jack up a little, check for movement. Jack up a little more and repeat.
Old Jan 15, 2023 | 07:25 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Check your struts also, the struts are what holds the wheels up when the car is lifted off the ground,
Old Jan 15, 2023 | 01:10 PM
Sounds like the ball joint.
Put your floor jack under the control arm and lift the wheel enough to get a 2x4 under the tire. Use that as a lever to pry the tire upwards while watching the ball joint (or have your assistant pry while you watch). If it moves, you need new ones.
Old Jan 16, 2023 | 06:58 PM
ughmas's Avatar
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
Probably as others have suggested likely a ball joint or strut mount bearing. Also check sway bar bushings and end links and look for other loose components when you are under there
Old Jan 16, 2023 | 07:14 PM
Engine: 5.7 TPI
Thank you everyone, I put a jack under the lower control arm and lifted the wheel up again and took the caps off the strut mounts so I could see the bolt. Turns out it was quite loose and was backed off about half an inch. I tightened it up and now should hopefully be able to road test it when I get new tires as I now cannot replicate the issues after removing the jack.
Grizzlybear226
Apr 13, 2008 09:20 PM
862nv
Jun 30, 2006 11:14 AM
thenewguy
Dec 27, 2001 11:05 AM
