Max torque a T-top car can handle with only sub-frame connectors????
Car: 92 Camaro RS
Engine: 305 TBI
I'm getting ready to build some kind of engine for my 92 RS T-top car and I only have the original Spohn rectangle sub-frame connectors. Also have a Strange S60 rear with 3.73 gears, I don't want to do anymore to the chassis so what should I limit torque too on the new engine to prevent twisting the frame too much? I will be using a TKX 5-speed. Not a race car just fun street.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Max torque a T-top car can handle with only sub-frame connectors????
The best subframe connectors are the Detroit Speed units. They truly box the car in make it incredibly stiff. There will be no set value of "power" that will alter the shape of the car. It will be a combo of things from traction, power usage of car, etc. Subframes connectors and a strut tower brace go a long way on these cars.
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
Made 670 ftlbs to the tires with only a bolt in set of subframe connectors in a t-top car. Zero signs of issues.
Car: 92 Camaro RS
Engine: 305 TBI
OK, just looking for 500 ft.lb. anyway. I guess I'll be ok. Just don't want to twist anything.
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
The car is going to "suffer" more twisting, driving it through a gutter entering a gas station, than it will from your torky engine. This is, as I like to say, "Worryin' about chit that ain't worth worryin' about".
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
I'm a T Top car with only boxed BMR subframe connectors and I'm pushing 850-900 HP without issue. That being said an 8 point cage is next up in the spring
I'm considering the Jegs brand SFC for about $300. Does anyone have experience with these? My T Top car has some salt damage and rattles badly. It was crashed into a ditch hard by the prior owner but rides fine and seems to drive straight after new tires and alignment. Mine is a daily driver not a race car.
JEGS Bolt-On Subframe Connector Set for 1982-1992 Chevy Camaro & Pontiac Firebird
Part Number: 555-64714
Car: 85 Berlinetta
Axle/Gears: 10 bolt 3.42 with Torsen posi
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Car: '90 RS
Engine: 377 LSX
Car: 1989 Firebird
Engine: 2.8 Liter V-6
How do these look/fit with the carpet reinstalled? I just assumed that the factory carpet wouldn't fit anymore, but it looks like you've got it in your car.
Car: '90 RS
Engine: 377 LSX
You don't even notice them and they only protrude a slight bit into the interior (where wiring goes, but I diverted it through the center console). As good as my fabricator was they welded the seat belt bolt bracket on backwards so the plastic interior cover doesn't fit well. Shouldn't be a problem . I just need to drill a hole and use a rivet to secure it like it came from the factory.
BrightRed93Z28
Oct 27, 2005 11:30 PM
