getting posi w or w/o disk recommended
Old Jan 28, 2002 | 05:03 AM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
i'm putting in posi rear to go with 350 this summer. i have an 83 sc with drum rear. are discs worth the trouble. 89+ rear disc are better, correct? how much trouble? what is required. yes i know this topic is kinda overposted but, i need this specific info. no i won't be getting four gen rear.
Old Jan 28, 2002 | 07:53 PM
Car: 86 Z28
Axle/Gears: TBD
any one at all
Old Jan 28, 2002 | 08:03 PM
TVP's Avatar
TVP
ok .. the 89 and up are better .. both in brakes and in
axles .. newer ones have 26? spline alxes to work
with the take off posi's ..which are cheaper ... if your
not getting a 89 and up .. the disk brakes and the rear
are probably a waste of time ... that's why I went 4th
gen rear .. under $500 complete and done !!!
Old Jan 29, 2002 | 04:45 PM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
Disc are better brakes,I don't know how
much or hard it is to swap over.If you can
do it,do it.Were did you get a forth gen rear
from that cheap.I want one for my 92 Z28.
Old Jan 29, 2002 | 07:05 PM
Car: 86 Z28
Axle/Gears: TBD
do i just change out the rear if its an 89+. No adjustable proportioning valve. no stock just new brake lines?
Help?
Old Jan 29, 2002 | 07:43 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Brake lines are different for 1983 (inverted flare vs bubble flare). But I will cover this later. For now get a 89+ posi disc rear!
Old Jan 29, 2002 | 08:28 PM
Car: 86 Z28
Axle/Gears: TBD
later meaning tech article
? or a later e-mail/ post?
Old Jan 29, 2002 | 08:42 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Tech
Old Jan 29, 2002 | 09:02 PM
Car: 86 Z28
Axle/Gears: TBD
beautiful
thanx
92projectcamaro
Dec 8, 2015 12:25 AM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
kitt23
Sep 26, 2015 07:48 PM
