Under car noise
Old Feb 15, 2002 | 09:52 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Under car noise
My car makes a jingling noise when I hit bumps and such on the road. Sounds like a metal strip would sound like if you bang it around. It happens anytime the car shakes. It is really starting to annoy me. Any ideas
Old Feb 15, 2002 | 10:14 PM
turningfast's Avatar
Most rattles like this end up being something with the exhaust system. Give your drivers side tail pipe a little taste of boot. A relitively firm kick and see if you hear it rattle. One thing tat rattles a lot on these cars on the exhaust is this band that supports th AIR line near the converter. Also check the heat shield bolted to the undercarrage above the converter.
Old Feb 16, 2002 | 12:10 AM
trans87's Avatar
I will try that out. I wouldn't of thought of the exhaust making a high pitch jingling noise but maybe it is. It's going to be replaced anyway. I will check it out. Thanks for the advice.
Old Feb 16, 2002 | 08:52 AM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Trans87,
You could also check the cat itself. This would cause more of a rattle than a jingle. When the ceramics broke inside of my cat it was very noisy. If this is the problem when you can tap on the cat it will rattle like rocks in a can.
For what it's worth bro. Good luck.
-Schultzy
Old Feb 16, 2002 | 09:59 PM
trans87's Avatar
Well I hit the exhaust and shook the cat and it's not those that is making the noise. I think it's something in the suspension. Any ideas
Old Feb 17, 2002 | 12:35 AM
It could be anythig almost. Were does it sound like it is coming from (front or back) ? Did you get under the car and start looking around?
Old Feb 17, 2002 | 01:20 PM
trans87's Avatar
It sounds like it is directly underneath the car near the middle. I tried to get a look but couldn't see anything that might be the cause.
Old Feb 17, 2002 | 03:26 PM
kessler89/2.8's Avatar
Car: sold the Z now i'm drivin a 81 toyota celica and an 01 Suzuki TL1000R
Engine: 90degree 998cc V twin
Transmission: 6 speed
it's...
probably either a heat sheild or the *insides* of your cat, my cat made all kinds of noises before i took it off.
Old Feb 17, 2002 | 03:47 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
I had a similar problem and it turned out to be a swaybar endlink.
Old Feb 17, 2002 | 05:08 PM
trans87's Avatar
I will check the sway bar that might be it. It is not the cat because I shook that pretty good and there was no noise coming out of that at all. I wish it was because that is all going to be changed in a month after I get a new set of Comp T/A tires. Since the tires are worn out especially the back ones
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
hokis
Aug 9, 2015 03:57 PM
BrianI
Aug 9, 2015 11:52 AM
