can anyoen look under rear of a S10 or G body or b body 82-up and see if ,,...
Old Mar 22, 2002 | 04:39 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
see if the brake backing plates are attached by just two screws coming from inside of the brake shoe area, youll see the ends of the two screws protruding through the backside through the axle tube flange, on any GM car 82-up with 7.5" 10 bolt axle and 9 1/2" x 2" brakes, or if any GM cars older than that that anyoen may have, may have the same type of brake backing plate design
I have myself in a mess now, i just got done removing brake drums off the 84 and i trashed the pass side drum and backing plate, the damn thing would not come off no matter how far i backed off the shoes, i backed them off and the drum spun free, it just would not slide off the axle flange, i beat on it and beat on it and trashed the drum, broke it and mangled up the cheap backing plate, but it was the only way..... so now im screwed,
whoever designs this stuff in GM just plain sucks
basically im curious about vehicles such as 82-up cutlasses, regals monte carlos, S-10's etc etc
also, if you do have a 82-up GM car or downsize truck and if it has the conventional style of backing plates that are attached to the axle tube flanges by the normal four bolts and nuts then i want to know this also !
what id like to do is upgrade to backing plates for the 7/8" or 15/16" cylinders, except that the damn third gen plates are wierdo style that are attached by only two screws to the axle tube flange, so.,,,, are third gen F body the only ones like this ?
anyone ?
thanks for anything
Old Mar 22, 2002 | 05:16 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Dude, I'm "about" to mangle the drum on my rear passenger side, too! (i put a message up about it a few days ago)! Glad to hear I'm not the only one that backed the shoes off and tried everything, to have the drum still stuck.
Old Mar 22, 2002 | 05:49 PM
j's92rs/z's Avatar
Car: 92 Z
Engine: 5.0
Axle/Gears: 10 bolt 3.42
The backing plates on my 86 GP 2+2 look just like the ones on my Camaro and along with the two bolts that big nut at the top that the springs attach to also hold it on
Old Mar 22, 2002 | 06:37 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
lol Tom, yeap, that pass side drum was not coming off without breaking out the bitg hammer and prybars, there was no frickin way at all.. didnt really hurt the driver side plate badly, just a couple bents spots on the outside diameter is all, so i have one good laum drum and one good plate, but im gonna swap good plates on both sides and i dunno what im gonna do about drums yet, i guess rob some off an S-10 or G boy or B body or something, and wheel cylinders i dont know yet, i need to find out if any of the S-10s used the same means of wheel cylinder attachment as our maros and if so then im gonna get a pair of manual brake S10 cylinders sine they are 7/8" bore
http://www.expressautoparts.com/stor...tegory=BRAKAMS
refrsh me on what GP 2+2 is, i forgot temporarily, lol
thanks guys ?
any other info anyone else may have would be good !
Old Mar 22, 2002 | 07:00 PM
j's92rs/z's Avatar
Car: 92 Z
Engine: 5.0
Thats a Grand Prix 2+2 or what some people call it an aerocoupe, and yes the manual s10 wheel cylinders will work on the g bodys so i dont see why it wouldnt work on the camaro after all they are both corporate 7.5s
Old Mar 22, 2002 | 07:25 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
well because they mount totally different, the maro uses some wird clip to mount on along with the two screws and i look ed up for and looked at a 84 caprice cylinder and its a totally different cylinder, its a normal conventional two screw cylinder, so...
and they ised 7.5" rearends mainly, so..
Old Mar 22, 2002 | 07:33 PM
j's92rs/z's Avatar
Car: 92 Z
Engine: 5.0
Hmm maybe its a b body thing i know that the g body wheel cylinder uses that funky clip thats a pain in the **** to get off
Old Mar 22, 2002 | 08:19 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
i dont know that S10 or B body do, but F body do and G body do apparently, also
i found pics of a 2+2 GP:
http://members.tripod.com/perfauto/g-bodyhome.htm
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Street Lethal
Aug 13, 2015 08:28 PM
