Sway bar bushings and end links
Old Mar 25, 2002 | 07:32 PM
stevver84Z's Avatar
Car: 1990 Iroc Hardtop
are there different sizes for these or are they all the same throughout the years??
i was looking on thunder racing and they have 3 different sizes of bushings and endlinks, how do you measure them??
Old Mar 25, 2002 | 07:35 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
The bushings for the bar you MEASURE the DIAMETER of the bar...IE 34MM or 36 MM.....
The end links you measure the SPACER between the grommets...There is a long metal spacer....Basically a piece of tube.....Measure that and buy the correct size...
Kenwood
ICON Motorsports
Old Mar 25, 2002 | 07:37 PM
stevver84Z's Avatar
sounds good thanks, what about the rear sway bar i only saw one size for that one, is it a standard size?
Kenwood's Avatar
Car: 1987 GTA
Transmission: th400
Axle/Gears: 9" ford
Yes there are all different sizes and combos on thirdgens...Some of which NO ONE MAKES BUSHNGS FOR...ei the BIG WS6/1LE bar....All you can do if you have one is BUY the largest greasable Bushing and use it...Thats what I did...Its a tight fit but the Grease will keep it from binding untill it wears in...
Kenwood
Old Mar 25, 2002 | 07:38 PM
Kenwood's Avatar
Car: 1987 GTA
Transmission: th400
Axle/Gears: 9" ford
Not sure on the rear sizes.... Ive Yet to replace any of the rear bar bushings yet..
Old Mar 25, 2002 | 07:41 PM
stevver84Z's Avatar
cool, i'll chek it all out tomorow.......call me stupid but its been a few years since geometry class....diameter is the length all the way around the bar?? correct??
Old Mar 25, 2002 | 07:44 PM
Kenwood's Avatar
Car: 1987 GTA
Transmission: th400
Axle/Gears: 9" ford
No not all the way around the bar... The diameter is If you CUT a circle in HALF what is the LEGNTH of the straight line....
To measure it just take a pair of calipers and close them on the bar... Or remove the old bushing and as long as its not too banged up you can get the diameter with a ruler...
Old Mar 25, 2002 | 07:46 PM
stevver84Z's Avatar
oh ok, thanks allot!!!
Old Mar 25, 2002 | 07:50 PM
Kenwood's Avatar
Car: 1987 GTA
Transmission: th400
Axle/Gears: 9" ford
No problem....I have to do the same thing with my rear bushings.... I switched to the 9" ford and had to get new ones...Ive just been to lazy to go out and measure the Bar...LOL
Old Mar 26, 2002 | 06:06 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Should anyone be interested in a 1LE hollow 36 mm front sway bar, please see my add in the classifieds.
JamesC
1992rs/ss
Jan 31, 2025 05:10 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
