IROC Z rear wheel spacer thickness?
Old Mar 30, 2002 | 04:27 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
What thicknesses are the rear spacers used on the IROC Z with the alloy wheels shown below and rear drum brakes (cast). I am going to fit them on my 1991 RS and haven't yet got the spacers. Where would these be located?
Thanks.
Andy.
Old Mar 30, 2002 | 06:36 PM
Z28DJP1987's Avatar
Andy
The info on the wheel spacers fpr your Alum. Wheels is as follows:
1) spacer thickness is approx. .150 +/- .020
2) GM p/n is 14091902
3) Price is $8.46 US each
4) Source is www.gmpartsdirect.com - Flow Chevolet in N.C. USA.
I hope this information helps you out. I just sold a set of these spacers, tough luck.
Old Mar 30, 2002 | 06:55 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I thought you don't need spacers for the IROC wheels???
Old Mar 30, 2002 | 07:04 PM
Z28DJP1987's Avatar
These are spacer for the rears when using 16" Alum wheels with
cast steel brake drums " ONLY". Not when you have Cast ALUM DRUMS, GM wanted to maintain the same spacing with the two
different materials. I hope this explains their use.
Old Mar 30, 2002 | 07:15 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Should these spacers be used with aftermarket wheels or is it personal preference?
Old Mar 30, 2002 | 08:16 PM
steve8586iroc's Avatar
I have two IROC's, an 85 and a 86. Both originally cam with alum. drums and wheel spacers. I also have a 91RS with factory 16" alum wheels and steel drums with spacers. Go figure.
Steve
Old Mar 30, 2002 | 09:18 PM
82camaro's Avatar
Car: 82 camaro SC
You really don't 'need' them. I don't want mine to stick out any further. They look correct to me.
Old Mar 30, 2002 | 10:44 PM
Hg's Avatar
Hg
Car: '87 Z
How do I know if I have steel or aluminum drums? I have an '87 Z28. I didn't even know I might need spacers. Pleeeeease tell me I don't need spacers, my tires should be here Friday... don't tell me I have to wait even longer When I painted my drums they didn't weight a WHOLE lot.... hopefully they're Al
Old Mar 31, 2002 | 10:48 AM
Z28DJP1987's Avatar
As a reply on weather to use the drum brake spacers, all I can say its up to you because its "No big deal not using them" its your choice. But GM used them for a reason.
Old Mar 31, 2002 | 01:37 PM
Hg's Avatar
Hg
Car: '87 Z
So I'd just need these spacers for the rear right?
Old Mar 31, 2002 | 06:34 PM
Z28DJP1987's Avatar
Two spacers (.150 thick) for the rear only, with cast steel brake drums.
Old Mar 31, 2002 | 08:17 PM
Hg's Avatar
Hg
Car: '87 Z
Do I need any spacers for the fronts? Or was it just the rear that needed them?
Old Mar 31, 2002 | 08:32 PM
Rear only, rear only, rear only.
Sorry my keyboard got stuck.:lala:
Actually you don't need then at all but it doesn't hurt to use them either.
Old Mar 31, 2002 | 08:36 PM
Hg's Avatar
Hg
Car: '87 Z
So it's just the pair of .150 spacers as mentioned above for the rear? Thanks. You're a lucky man, not only an IROC, but 2 IROCS! Dang u, and all I have is a normal Z
Old Apr 1, 2002 | 12:54 PM
82camaro's Avatar
Car: 82 camaro SC
Hg, bolt them on and see what you think. If for some reason you want them to stick out .15 more, then get some spacers. A .15 spacer is a waste IMO. A little more than 1/8 inch.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
