cant post a poll so........
Old Apr 24, 2002 | 09:16 AM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
for some reason the moderators took away all my options because i made a stink about them erasing my avatar so therefore i cant post a poll so i have to do it this way..........right now i have an edelbrock perfromer tbi with the stock 1 11/16 tbi........in the future im going to be putting vortech heads and a vortech intake however i cant afford to do it at this time since im trying to buy a house...........i was going to get the bored out high flow 1 11/16 tb from turbo city............my question is this.....should i wait till i do the motor work and get the holley 2" bore tbi or will the 1 11/16 high flow be enough for later on...........you can make the answers short,and yes i have read the posts on a search i just want to see what comes up here
1 11/16 high flow
2" holley
Old Apr 24, 2002 | 01:43 PM
JR305's Avatar
I am going to use the stock TBI with the ultimate TBI mods and 350 injectors. My setup can be found herehttps://www.thirdgen.org/techbb2/sho...hreadid=101405
I am not sure what Turbo city does to the TB, but I think they just do the ultimate TBI mods for you.
My vote is for the stock TBI with the ultimate TBI mods and upgraded injectors. I think this is what DM91RS has done and he is running vortec heads.
Old Apr 24, 2002 | 01:52 PM
wasp's Avatar
yea they bore it out and shave the throttle shaft, i allready have flow matched injectors,a 1/2" spacer, the injector spacer,afpr......take a look here the pic shows you the difference............http://www.turbocity.com/TBIPowerMain.htm
Old Apr 24, 2002 | 02:02 PM
JR305's Avatar
Yeah, it looks they do a good job, but for $229.00 + $200 core, I think I would rather spend a few hours with a dremel doing it myself.
If you I were you I would ethier do the Ultimate TBI mods or wait until you can do the heads and buy the Holley unit.
Old Apr 24, 2002 | 02:12 PM
wasp's Avatar
does anyone have a pic of a job they did themselves? can all of what turbo city does be done with a hand dremmel? im pretty good with tools i just wasnt sure if i could achieve the same results
Old Apr 24, 2002 | 03:25 PM
iroc22's Avatar
The Holley will take you further because of it's unported flow rate. The Turbo City one is nice if you want to keep you're 1 11/16 manifold. I would get the Holley if you want big HP #'s.
Just wait dont jump into anything. Everything will fall into place later.
Old Apr 24, 2002 | 03:29 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Holley.
Old Apr 24, 2002 | 03:53 PM
wasp's Avatar
i think what ill do is buy a dremel and just do the one i have now myself then ill buy the holley when i do everything later on......my only question is i assume when you shave down the throttle shaft you also shave down the throttle screws or pins that hold the plates onto the shaft........doesnt this weaken the plate to shaft connection? any chance of the plates coming off?
Old Apr 25, 2002 | 10:01 AM
wasp's Avatar
mmmmmmmm has anyone actually done this? it looks to me like you have to remove the stock throttle plates and make bigger ones..........
Old Apr 25, 2002 | 10:31 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have the Turbo City throttle Body on my 350.
It works well, and I'm making over 300HP at the flywheel,but the $200 core is awfully high.After I got mine the note that came with it said they had to have the core in 10 days or they won't give me my $200 back! Mad scramble through local yards to get a core, so I could keep my original (wanted to keep my old one because I knew it had no leaks).
Also, the Turbo City throttle body was very warped on the bottom.I had a horrendous vacuum leak after I first installed it.
Only took a few minutes with a block of aluminum and a piece of sandpaper to flatten it out, but for that kind of $ you shouldn't need to repair it!
Reason I went with Turbo City instead of Holley was that I'd heard that the GM Injectors are more tolerant of fuel pressure increase and last longer, but I've heard that Holley has corrected those problems on their latest TB's.
Some have modified their Holley Throttle Bodies to accept GM Injector Pods, and this seems like a viable alternative as well.
If I had to do it over, I'd go with the Holley Unit and if the Injectors gave me trouble I'd just mod the TB to accept the GM Pod.
-Rich-
Old Apr 25, 2002 | 12:23 PM
wasp's Avatar
were the throttle plates bigger than stock on the turbo city tb rich?
Old Apr 25, 2002 | 12:34 PM
Car: 92 Camaro RS
Yeah, they have larger plates, a ground thinner shaft and tiny buttonhead screws. They also mill off the material at the top of the TB and polish the enlarged bores.http://www.turbocity.com/TBIPowerMain.htm
-Rich-
Old Apr 25, 2002 | 01:17 PM
wasp's Avatar
mmmmmm think i could get the same results with a dremel myself rich? at first i thought yes now im thinking they do a much better job
Old Apr 25, 2002 | 03:36 PM
Car: 92 Camaro RS
The polishing is easy enough and so is milling off the material on top.Both of those could be done with a dremel.
Not sure how to go about actually increasing the diameter of the bores. I've seen some discussion about throttle plates and I know they're available from a couple different sources.
I think it'd be best to use a mill and the proper size bit on the throttle bores.
Anybody else have any input on this?
-Rich-
Old Apr 25, 2002 | 03:56 PM
wasp's Avatar
yeah when ya look at the picture of theirs it seemed to me that youd have to remove alot of material to get the bores that big,thats what i mean, i dont think you can get em that big with a dremel
Old Apr 26, 2002 | 10:22 AM
FRMULA's Avatar
You can't, the bores need to be milled and new throttle plates made. Anyone with basic metal working skills and access to a metal shop can do this...
Old Apr 26, 2002 | 10:28 AM
wasp's Avatar
well then heres the next problem.............i have an edelbrock tbi intake with 1 11/16 bores........wouldnt the intake need to be dilled out as well?
Old Apr 26, 2002 | 10:34 AM
Car: 92 Camaro RS
I'm using the Edelbrock TBI intake as well.
Both Edelbrock and Turbo City recommend only chamfering the bores of the intake...not boring it out.Between this and the thickness of the gasket, it should be enough.
I did this and it clears fine.Now if you get the really big Holley TB,I think you'd have to bore it out, or go to the Holley TBI intake or a four-barrel carb intake with a TB Adapter.
-Rich-
Old Apr 26, 2002 | 10:38 AM
wasp's Avatar
by chamfering you mean using a dremel and just angling the edges of the hole? to make like a funnel shape instead of just a clean cut circle correct?
Old Apr 26, 2002 | 10:46 AM
Car: 92 Camaro RS
Yep, that'll work.I used a chamfering bit on mine, and used the mill at work, but you only need to take about 1/16" of material off.
I would think boring it all the way through would be better, but like I said before, they recommended against it.
-Rich-
Old Apr 26, 2002 | 11:04 AM
wasp's Avatar
im probly gonna do it with the intake on the car ,ill just stuff the hole with a rag.....they dont make a chamfering bit for a dremel do they? hehehehe im a carpenter dont know much about metal work
Old Apr 26, 2002 | 12:13 PM
Car: 92 Camaro RS
A rag with some grease on top will collect the shavings well.
-Rich-
Old Apr 26, 2002 | 12:27 PM
wasp's Avatar
good idea, hey thanx for the reply rich
pjsparts
Oct 29, 2025 06:39 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Linson
Sep 21, 2015 01:08 PM
Strick1
Sep 6, 2015 02:21 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
