Vortec Heads and TBI
Old May 14, 2002 | 09:20 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
I'm not real familar with the TBI system, or the vortec heads for that matter. I did a search and found the intake post, but not awhole lot on vortec style.
Does anyone know of any aftermarket intakes that run a factory style TBI but bolt to vortec style heads?
Old May 14, 2002 | 09:23 PM
steve8586iroc's Avatar
Edelbrock makes one.
Old May 14, 2002 | 11:23 PM
iroc22's Avatar
GM is the only true bolt up Vortec TBI intake that I know of. And they're price is like $250 or something rediculous
Old May 14, 2002 | 11:26 PM
JPrevost's Avatar
Car: 91 Red Sled
Edelbrock RPM vortec sqaure bore intake with an adaptor plate works for me.
Old May 15, 2002 | 12:36 PM
Ions91Z28's Avatar
Old May 15, 2002 | 09:30 PM
bigREd car's Avatar
Car: camaro
Engine: mighty 305
Transmission: mighty 700r
the vortecs arent plummed for egr also if you didnt know that... you have to run an external egr which jprevost and others can go into much more debt about then me..
i wouldnt expect an answer from jprevost today though it looked like he turned 21 today... happy b-day man...
i would love to run vortecs but i dont want alot of hassle if i could just get a straight answer on how to bolt it up to my tbi it might happen soon... along with a 350 and lt1..just my sob story and 2 cents..
Old May 15, 2002 | 09:35 PM
HrdRockA4305's Avatar
Don't the S/R torquers have EGR provisions? I mean they aren't quite as cheap as Vortecs, but if it has that, and uses a normal intake, it might be less hassel or cost if you figure everything together.
Old May 15, 2002 | 10:35 PM
bigREd car's Avatar
Car: camaro
Engine: mighty 305
it all changes if you plan on swapping to a 350 eventually which i want to do...
Old May 15, 2002 | 11:21 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
hey man, i dont want to pretend that i am a TBI master or anything, but if you check out my website, there is a lot of info as far as bolting TBI up to Vortec heads.
The tech parts of my site are far from finished, but nonetheless there is a section on "adapting TBI". some of the other sections may have some valuable info too.
any questions, let me know. addy is in the sig.
-brian
Old May 15, 2002 | 11:44 PM
JPrevost's Avatar
Car: 91 Red Sled
do a search on the board for "egr vortec jprevost" you should get plenty of good reading material to fall asleep too.
In a sumation, stock computers can be fooled into thinking there is EGR but that'll change the timing (advance) and THAT is what causes the most problems. You could program your own eproms and could simply disable EGR. How do you think I passed the NJ emissions tests with my car?
Old May 16, 2002 | 10:40 AM
iroc22's Avatar
Yeah they do have EGR, that's why I went with them.
Old May 16, 2002 | 11:14 AM
JPrevost's Avatar
Car: 91 Red Sled
EGR = better gas milage so long as it's working and you aren't towing a boat! But what can I say, 3.73 gears and I still get 22mph on the highway .
I do wish I had EGR stll but the vortec heads are just that good and I never looked back.
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
