Am I ok with this setup?
Old May 15, 2002 | 11:40 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Here's what I've bought:
3.42 posi rear
3" Flowmaster catback
3" cat
1 5/8" w/3" y pipe MAC headers
L31 Vortec heads
LT1 cam
Now I need to finish it up, heres what Im thinking:
Edelbrock Performer RPM intake
Holley 4bbl -> tbi adaptor
GM 2200 stall
Does it seem like a good setup, or should I change some stuff? Suspension stuff will come in about a month once I get some more money.
Thanks!
*edit*
I cant afford the 2" tbi right now, either, but I know I need more fuel. What injectors should I run (color wise)?
Old May 15, 2002 | 04:56 PM
NJ SPEEDER's Avatar
that set up shoudl be fine. my only suggestion woudl be a little bit looser torque convertor. something in the 2800 range will be better for the LT1 cam.
later
tim
Old May 15, 2002 | 05:06 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Yeah, sounds like a good setup to me.Like NJ Speeder said, a little more stall (or a manual trans) will make it better.
-Rich-
Old May 15, 2002 | 06:24 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Yea, that was my largest concern... what stall to run. Thanks for your suggestions.
I guess my last question is, would you get the heads milled .045 down to keep compression up, or just leave them how they are so they can be easily thrown on a 350?
Old May 15, 2002 | 09:27 PM
NJ SPEEDER's Avatar
i woudl mill them, even if you throw them on a 350 you can just get stock style flat tops with valve reliefs and still be pump gas friendly.
later
tim
Old May 16, 2002 | 02:36 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Beautiful. I would have your children if it were possible, Tim.
Old May 16, 2002 | 07:24 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Ok, one last question, honestly
Injectors, what should I run? I dont think the 305 injectors will be up for it, with higher pressure.
Old May 16, 2002 | 07:50 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Maybe, if you're feeling saucy, you could toss in a few extra dollars for an RPM Air-Gap manifold. Hot Rod Magazine loves these things and they work great with vortecs.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
