After my Cam/Intake Swap....
Old May 21, 2002 | 04:13 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Should I think about getting a higher flowing TB unit? I did the ultimate TBI mods already to this tb and did the afpr and injector spacer but it still feel sluggish around 4000-4500rpms. Do u think I would just need to upgrade my injectors or to a 454 TB unit after the cam and intake swap? I don't have any head work to the engine but I do have a full 3" exhaust system, no cat and Edelbrock TES Headers with the 3" collector. So I am gonna get all the power I can from that LT1 cam so it will be pusing my motor for air pretty bad and fuel.
Old May 21, 2002 | 04:53 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Whats the point of swaping the intake if you aren't gonna swap the TB?
The 2" diameter of the TB openings will help quite a lot and you will really realize the potential of the engine At least, until you do heads.
Old May 21, 2002 | 05:21 PM
vjo90RS8's Avatar
Car: 2002 Z28
or...bore the stock TBI unit out to 48mm and use the stock TPI throttle blades. This is pretty close to 2" inches (50.8mm)
Old May 21, 2002 | 07:03 PM
steve8586iroc's Avatar
I don't think it's time for a bigger tb just yet. You might look at you advance curve. You could be having some timing taken out by the ecm due to preignition or you could be running a little lean. Do you have access to a scan tool or winaldl? This would help you find the trouble faster and keep you from making unessasary changes that might make matters worst.
Steve
Old May 21, 2002 | 07:24 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Well I don't want to do it if its gonna be an overkill, thats why I am asking. Of course it will flow better and blah blah but do I need it? I have the Windal software but I haven't bought the cable yet (I got it for 29 bucks, I am lazy. )
Old May 21, 2002 | 08:18 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
I think the ultimated TBI will be fine. I think the swirl port heads will be the restriction at that point.
Old May 21, 2002 | 08:48 PM
Tas's Avatar
Tas
:lala:
Old May 21, 2002 | 08:53 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
LoL, the guy can't use his keyboard so I have to read picture langauge. Lets see. That must be Taz looking at my throttle body and then his dance must mean everything is ok and then thats him waving goodbye and peeling out in his car. How did I do Taz?
Old May 21, 2002 | 08:56 PM
Tas's Avatar
Tas
Old May 21, 2002 | 10:46 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
91Bird305,
I've said it before and I'll say it again. I have the stock intake manifold and cam (unfortuantly), with my only real mods being a very strong ignition setup, open element, and full exhaust. My origional TBI injectors were going bad, and I found for the price, the holley 670 to be a good deal. I bought the 502-5 w/ 57lbs injectors. And it works GREAT!!! No questions asked. Nice SOTP.
So when people tell you not to go with the 2" TBI, realize that the extra air does help, just be careful when matching your injectors.
Old May 21, 2002 | 10:51 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Hmm, maybe I should look into a 454 TB unit then. Then get my injectors flow matched at this local place....
Old May 21, 2002 | 11:01 PM
Tas's Avatar
Tas
ISERCASTiK@aol.com Jeremy might have a 454 TBI for you. He got one for Pablo. I got some '99 Camaro seats from him 2 weeks ago.
Old May 21, 2002 | 11:15 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
drooooool......leather?
Old May 21, 2002 | 11:16 PM
oh yeah i would go with a larger TB
Old May 21, 2002 | 11:27 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Can anyone give me some info on the 454 TB units? Like cfm rate, injector sizes, etc... thanks.
Old May 22, 2002 | 12:14 AM
Tas's Avatar
Tas
nah. I'm gonna test fit my old seats in my Jeep. If they fit in the Jeep I might put these gray cloth '99 seats in there and get leathers for the firebird.
Old May 22, 2002 | 08:57 PM
91, the GM 454tbi is rated the same as the Holley 670cfm tbi and come with either 80# or 90# injectors.
Steve
Old May 22, 2002 | 09:00 PM
and i think they have different throttle mounting plates. ask snuf
Old May 22, 2002 | 10:15 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Don't they come with 65lb injectors too?
Old May 22, 2002 | 10:18 PM
nope i think only 90 something lb/hr injectors
Old May 26, 2002 | 01:01 PM
Engine: LO3;383tpi
The Holley 670 (502-6) comes with the 65 lb injectors. The 502-5 comes with 57 lb injectors. The 454 TBI I believe comes with 80 lb or 90 lb injectors i think.
derekvargason
Jan 21, 2014 08:54 PM
VandykeT/A
Jan 5, 2013 02:58 PM
91ChevyRS
Dec 6, 2005 07:13 AM
86FirebirdV8350
Carburetors
May 22, 2003 08:25 PM
TonyC
May 10, 2003 05:56 PM
