Stock intake vs Edelbrock Performer RPM - pictures
Old Jun 23, 2002 | 02:48 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I thought the Performer was going to be much higher, but the freaking giant Holley adaptor is what is going to kill me.
Two more pictures:
http://homepages.udayton.edu/~kulcha...omanifolds.jpg
http://homepages.udayton.edu/~kulcha...ifoldsside.jpg
Just incase you were curious as to how the Performer RPM compares in size to the stocker.
Old Jun 23, 2002 | 08:20 AM
Slade1's Avatar
When you measured the clearances, how much did you have to work with? I'm planning on doing the same kinda swap and was wondering if I should go Performer RPM w/EGR (carb) + adapter or Performer TBI RPM w/adapter. If it still manages to fit let us know!
Old Jun 23, 2002 | 09:03 AM
DM91RS's Avatar
Car: 91 RS
I installed a Vortec performer RPM yesterday. I have about .375" clearance to the highest point of the breather to the hood. I used a .375" tall adapter plate. I also have a 1" taller breather top installed with a stock bottomed breather. You might fit that setup with a stock height breather.
Old Jun 23, 2002 | 11:50 AM
Birdman7389's Avatar
hello all, i've been hanging out for a while but I just got my login stuff straight. Will a regular (carbed) manifold work ok with the TBI adapter? I got a RPM Air gap in my shed but it for a carb and my current vehicle (1989 Trans Am TBI 305/700r4). I'm just curious if it would work ok? Thanks
Old Jun 23, 2002 | 01:49 PM
iroc22's Avatar
Yeah but notice how much higher the runners sit on the Edelbrock compared to the stock unit.
Old Jun 23, 2002 | 05:42 PM
StangKiller's Avatar
You can get you adaptor milled down thinner at a machine shop if it's too tall, and what monkey have you been letting take off your wheels? That center cap in the last picture sure is dinged up bad!!!!
Old Jun 23, 2002 | 06:02 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
what kind of air filters are you people using (dont have one on there right now)? I donno about you but i had to do some ghetto riggin' to get all my stuff to bolt up to the edel. intake. I had to move my brake booster hose to where the vacuum port for the climate climate control is and my coil sits closer to the tb then it did before.
Old Jun 23, 2002 | 11:16 PM
TBI305Camaro's Avatar
looks good. thats my next mod. was about to buy it but i suddenly got a few other expenses (well one....female)
Old Jun 24, 2002 | 01:56 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
The way the adaptor is the bores go from 2" and taper in twards the square bore, if I got it milled then I'd have a lip from the intake manfold before the air/fuel got into the manifold.
Nothing wrong with the center cap, just funky lightin in the picture.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Sep 17, 2020 08:26 AM
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Aug 17, 2015 02:00 PM
TreDeClaw
Aug 14, 2015 06:58 PM
