What to do with PCV hookup after open element installation?
Old Jul 7, 2002 | 12:34 PM
RS'er's Avatar
Yeah,I've just had it dangling there for the past six months... Should I replace it with some sort of a crankcase filter? What have you guys used or should I even worry about it?
Old Jul 7, 2002 | 01:55 PM
Tas's Avatar
Tas
3/4" push in breather. $4
Old Jul 7, 2002 | 02:18 PM
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
the pcv valve is on the drivers side of the engine. installing a open element has nothing to do with the pcv valve... are u talkin about that rectangular shaped filter on the pass. side?
Old Jul 7, 2002 | 02:21 PM
Tas's Avatar
Tas
I think he's talking about the tube that goes from the pass side valve cover up into the air cleaner. Its a breather so just get a push in breather.
Old Jul 8, 2002 | 03:42 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
This tube on a stock setup connects to the rectangular filter he is talking about.
Old Jul 8, 2002 | 03:44 PM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
I also would like to know what to do with this thing. I'm guesing he's talking about the crankcase filter. The thing with all the gunky crap on it.
Old Jul 8, 2002 | 04:40 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
mr. gasket part number 2057
720-2057 if you are in jegs right now
Old Jul 9, 2002 | 11:01 PM
92BlAcK_RSLO3's Avatar
Hello Im in the process of buying too an open element air filter (have not decided wich one to get yet, considering the composite comp cams one) so I needed to know what to do about that breather, So I found two kinds one with PCV (Its also a breather) and one standard, What should I do replace the drivers side with a breather that include a PCV and the passanger one with a standard breather?
Thanks.
Any recomendation on the open element is greatly aprecited (I need to buy it from summit)
Old Jul 9, 2002 | 11:18 PM
you can leave the drivers side alone. just get the part i mentioned above for the passenger side. if i were you i would get the cheapest flat base 14" air cleaner you can find. drive with the crappy paper filter until you need a new one then get a K&N
Old Jul 10, 2002 | 12:05 AM
So I would only need the drivers side one if the PCV valve was damaged right?
Thanks for the tip, Can I Choose any 14x3 air cleaner assembly if its base is flat, right? (everything else is stock)
Old Jul 10, 2002 | 09:59 AM
yep, in http://www.jegs.com these are the two parts that you would need:
720-9790
and
720-2057
Old Jul 10, 2002 | 12:29 PM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
On a related note...
Anyone know where I can get the black rubber grommet for the psgr valve cover, where that push-in breather installs? My original one is a mess (split in half), but I'm still using it (with the new breather) b/c I couldn't find one that fits.
Old Jul 11, 2002 | 05:48 AM
Pukka's Avatar
Re: On a related note...
Just take the old grommet and breather down to a Pep Boys type place and look for what you need. If you just ask them for the stock replacement you may not get the right size.
Old Jul 11, 2002 | 09:55 PM
TBI305Camaro's Avatar
i had the same problem...mine broke. I just have the stock type breather filter bent in half and stuck in there seems to work fine but looks stupid. Soon as I find a breather that fits I will buy it. I think I'll take the valve cover in there when I remove them to repaint them. You will notice a pretty good difference with an open element.
Old Jul 20, 2002 | 01:08 AM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
to get the rubber grommet go to pepboys or autozone and go to the help isle they have a lot of different sizes thats were i found mine
Old Jul 20, 2002 | 01:23 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Check this out . It's a screw on Lawn Mower muffler
$5.... Any hardware store has 'em. Fits right in the factory grommet too. I made a replaceable filter out of a few pieces
of blue shop towel cut out to cover the top of the "Breather".
And attached it with some tie wraps around the breather.
When it gets dirty and needs to be replaced I just cut out two more pieces of "Blue Shop Towel" and tie wrap 'em on.
Way better than K&N.....
Attached Thumbnails What to do with PCV hookup after open element installation?-rpm5a.jpg
mdtoren
Aug 23, 2015 12:52 PM
1985chevydude
Aug 20, 2015 12:29 AM
wruiz
Aug 13, 2015 09:07 PM
