Single planes
Old Jul 20, 2002 | 01:59 PM
MericanMuscle's Avatar
Single planes
I was wondering if there is any single plane mainfolds out there that have egr for the LO3. I cant seem to find any anywhere.
Old Jul 20, 2002 | 02:09 PM
Tas's Avatar
Tas
7525 weiand/holley
Old Jul 20, 2002 | 02:25 PM
Thank you.
Old Jul 20, 2002 | 02:33 PM
Tas's Avatar
Tas
Old Jul 20, 2002 | 03:57 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
Why would you want to install a single on a L03?? A good dual plane would work the best I would think. I take it you have a different hood? The single I have on my other car is kind high. Not sure if you have the aircleaner room. Just a thought.
Old Jul 20, 2002 | 07:47 PM
I think a single plane like a torker or stealth would fit under the stock hood of a 89 formula and some people have done it on here. I read alot about the single vs. dual plane and a single plane would have a higher rpm range. Basically i wanted a single because that might help solve the power problem after 4200rpm.
Old Jul 20, 2002 | 10:04 PM
Tas's Avatar
Tas
palric made his L03 run 13.9 with the 7525 weiand, 670 TBI, ZZ4 cam, 3.42s, 5 speed, full exaust, custom chip, no power adder, and untouched stock heads...and other stuff he probably didn't mention
Old Jul 20, 2002 | 10:28 PM
The manifold will fit your stock heads?? It says that its for the old bolt patten and 87+ aluminum heads. If it does fit then i will be a very happy person
Old Jul 20, 2002 | 10:51 PM
foxandfoe's Avatar
All you have to do is modify the two middle bolt holes on either side of the carb. You do this by drilling a different angle thru the bolt holes.
Old Jul 20, 2002 | 11:00 PM
Instead would you be able to use the sr torquer heads for the old bolt pattern??
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Nov 7, 2015 06:50 AM
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
dusterbd
Sep 29, 2015 08:40 AM
