TBI Chip question
Old Jul 27, 2002 | 12:58 PM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
TBI Chip question
How well would a Caprice Cop Car 350 TBI chip work in my car. Check my sig for mods. In about 2 months I will be doing LT1 cam and Edelbrock TBI intake swap. So if it wouldn't be that great now how about after that cam and intake are on.
Old Jul 27, 2002 | 02:03 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
You'd be very lean.
Old Jul 27, 2002 | 03:02 PM
Car: 89 Camaro RS
Engine: 305 TBI
Even with the AFPR?
Old Feb 4, 2003 | 09:00 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Lean? I don't know about that. Seems like you would be rich if anything. 350 chip for a 305? Is that right?
Old Feb 4, 2003 | 02:20 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Cop chip won't help a 305 car. Custom chip is the only way to clean it up and make it run the way it should.
Old Feb 4, 2003 | 03:07 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
i was running the cop car chip for 2 months before taking out the 305 and putting in a 350. i think the chip has a better timing and fuel curve. but im pretty sure you would not be lean. rich if anything. i think there was a slight difference probably fromt eh timing change. this was all on a 305, with msd coil, and no smog or ac, open element air.
Old Feb 6, 2003 | 10:52 AM
JPrevost's Avatar
Car: 91 Red Sled
You also probably felt more of the tcc than anything else. You'd be amazed at how slight changes in the lockup/unlock tables can make you think there is a difference.
Old Feb 6, 2003 | 12:16 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I'm guessing they are saying you would run lean because the 350s in the cop cars came with 65pph injectors I believe. The L03 came with 40pph injectors. Because of the larger injectors, the duty cycles may be less in the caprice chip. The computer doesn't know the size of the injectors either, so thus running thru 40pph injectors, it would be lean. However, I don't know what either charts look like, and couldn't tell you how the duty cycles compare.
Old Feb 6, 2003 | 03:23 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
the tcc would have made a difference if i had a auto.
Old Feb 6, 2003 | 09:56 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: TBI Chip question
Not too well.
For a chip designed to work with 65s to be used on any injector size other then that will generate odd problems if you just try dranking up the FP to get the same lbs.hr rating of the other injectors.
Also,
The vac signals from the stock cam to a LT1 will be enough different to be noticeable. least to me.
generic chips, are generic chips, to get one right for your car means doing your own, or settling for what someone thinks your car will like.
MustangBeater20
Oct 29, 2022 09:20 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
