K&N filter and now a bad noise from TB
Old Jul 30, 2002 | 11:22 AM
jawzforlife1's Avatar
So I just jot my K&N filter and a week later I have a loud rattle noise (dont know if it is related to new filter) from the TB. I hear it faintly when I have the engine running, But it is really loud when I press the gas pedal. I took off the filter cover and look at the TB. The 2 "blades" had moister on them and when I put my ear to the TB I could really hear the rattle.
Could a fuel injector have gone out. (the moister be fuel). Those are the fuel injectors right on top correct?
Sould I stop driving it until I get this prob fixed?
Old Jul 31, 2002 | 07:43 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Are you sure your not just hearing the injector pulses. They can be rather noisy. If your K&N is an open element, I would say that is definitely the case. I could hear mine inside the cabin of my truck. I don't hear it in the car with the dual snorkel air cleaner.
Old Jul 31, 2002 | 09:06 AM
TBI305Camaro's Avatar
if the car runs fine there probably isnt anything wrong. TBI seems to be very noisy. I even got some new noises with the intake to. Really loud whitle...sounds like a vaccum leak but ive checked and checked and cant find anything.
Old Jul 31, 2002 | 11:15 AM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
After I installed my Open Element air cleaner, I didn't hear anything but a louder swoosh of air when I reved the engine up. If you hear Rattles, something is wrong. Most likely a bad injector.
Old Jul 31, 2002 | 10:35 PM
So i brought it to my grandpa's. We were looking at the injectors (were the sound was coming from) and when you put you finger in both the one on the right shook alot more, does that mean it it bad. I got some fuel injector cleaner, I'll try that on the next gas fill up.
Old Aug 1, 2002 | 12:27 AM
GKK's Avatar
GKK
The fuel spraying out of the Injector should have an upside down funnel shape and the Injectors should not be loose. Do the Ultimate TBI mods since you're going to be taking the TB apart to install the new Injector.
Old Aug 1, 2002 | 11:04 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
You have a 11 year old car with 11 year old injectors. They are bound to make noise due to their age. Let me guess it is a timed click click click click. Oh and the moisture on the throttle blades is the fuel from being sprayed on it from above......
Kat
Old Aug 1, 2002 | 11:09 AM
Kat
yes and yes.
So i need a new injector, do I replace both or just the bad one.
Old Aug 1, 2002 | 11:18 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Mine have been clicking loudly since I've first got the car over 3 years ago. I havent had a problem yet.
Just check to make sure that the spray pattern is in a nice cone shape. If it is then great dont worry about it. If it isnt well ummm send your injectors out to http://www.cruzinperformance.com/ and get them cleaned and flow matched
Kat
Old Aug 6, 2002 | 07:22 AM
The clicking doesn't hurt anything. If the car is running fine then they are fine. The only time I replace one is when one stops working (which hasn't happened yet) or if one starts leaking. I test for leaking by watching the injectors while my wife turns the ignition on (not engaging starter). They should not drip or spray while the fuel pump is priming. If they do then replace them. If not they are fine.
Old Aug 6, 2002 | 03:11 PM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
hell, I always thought that the clicking was an exhaust leak at the manifold or something, but the car ran fine. I put my headers on this weekend and the clicking went away, but that's just because I'm runing open headers and I can't even hear the radio.
Old Aug 6, 2002 | 05:41 PM
Open headers is crazy. I had to drive my near stock 305 TBI about 9 miles to the local exhaust place. It was nutz sooo loud ity wasnt funny. I made some mustang guy at the gas station crap himself tho
Old Aug 6, 2002 | 06:19 PM
Slade1's Avatar
I did almost the same thing cept my car busted the connecting pipe to the cat on a speed bump... I remember starting my car one morning and it sounded like a beast! I drove happily the 15 mins it took to the muffler shop... scared a few people with how loud it was hehe...
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
