Gear Drive?
Old Jul 30, 2002 | 07:19 PM
Camero90tbiRS's Avatar
Gear Drive?
How do gear drives work with a fairly stock motor and a slightly modified tbi engine? I was going to get the 139.99$ petejackson gear drive. Will i need any extra mods to use it?
Old Jul 30, 2002 | 07:29 PM
NJ SPEEDER's Avatar
gear drives and knock sensor sdo not get along very well. it is also not a performance item really. it will not add any poswer or anything. it is just a bit mroe durable than a chain since it can't ever stretch.
later
tim
Old Jul 30, 2002 | 07:44 PM
Guest
Guest
Posts: n/a
later
tim
More quotes from the rumor mill eh?
A 'quiet' gear drive properly installed doesnt affect the knock sensor one bit. Theres even people running noisy ones.
Old Jul 31, 2002 | 03:54 AM
can this hurt my motor or make it run poorly?
Old Jul 31, 2002 | 04:44 AM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
The only reason to go to a gear drive is because it is really precise,it's for people with race motors who degree in their cam's to 1/2 a degree and want to make sure it stays right there for optimum performance.
You don't need one,don't go looking for problems
Steve
Old Jul 31, 2002 | 11:11 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
I LOOKED AT THAT DO BUT JUST GOT THE CLOYES DOUBLE ROLLER TIMEING CHAIN FOR MY 91RS. IT WAS LIKE AROUND 80 DOLLERS OR SO. IF YOU NEED THE PART NUMBER I HAVE IT AT HOME. GEAR DRIVES TO EXTREME FOR MOST STREET DRIVERS.
Old Jul 31, 2002 | 11:40 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I didn't know they made one for the roller cam's bolt pattern do to the knock sensor issue. Too much work to test and then have to take it back out.
Old Jul 31, 2002 | 04:47 PM
Guest
Guest
Posts: n/a
Yea, they make one for factory roller cams. It setting off the knock sensor is the biggest pile of on the face of the planet. And then people insist on spreading a rumor they have no evidence to support.
<----- Trying to kill a stupid myth, but people just dont listen.
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
