Open Element TBI
Old Aug 1, 2002 | 03:26 PM
LowStyle187's Avatar
Open Element TBI
Anyone got any pics of this....what all parts did you need.
I looked in the tech articles and the only major part is the non drop air cleaner base.. WIll this work with my current K&N filter?
Where could I pick up a aftermarket base.. Should I try the autoshops or Chevy House? Thanks
Old Aug 1, 2002 | 05:18 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
I don't think that it will work. The diamater is different. One thing you could try to do is to cut a peice of sheet metal the same size as the air filter. Or go out to a scrap yard and buy another air filter housing and mod that one to an open air filter if you want to keep that K&N. As far as open housings go, you can go to a local parts store or through summit.
Old Aug 1, 2002 | 10:14 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
just check your local auto parts stores first. get a 14" flat bottom air cleaner with filter
Old Aug 2, 2002 | 12:13 AM
TBI305Camaro's Avatar
Make sure you get a NON DROP base...i cant stress this enough. NON DROP base...I had a drop base and it sucked....once again NON DROP BASE
Old Aug 2, 2002 | 09:44 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I'm running the Moroso Flat Bottom Air Cleaner, 14x3", part#65911, with a K&N Element. $48 at Summit.
There are certainly cheaper ones out there, but this one fits well and looks good.
Any flatbottom air cleaner will work. Drop base will still require the spacer, so like TBI305camaro said, try and stick with a non-drop base (flatbottom) if you can.
-Rich-
Old Aug 2, 2002 | 10:21 AM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
RICH92RS350 - do you just put your stock air cleaner back on when it's time for smog inspection?
Old Aug 2, 2002 | 10:22 AM
Car: 92 Camaro RS
Yep....just takes a couple minutes every two years.
-Rich-
Old Aug 2, 2002 | 03:54 PM
When I had the drop base I still had to use the spacer ring. Im sure that cuts down airflow alot. It also touched my cruise control cable and coil. The NON DROP has neither problem. Although with the edelbrock TBI Intake it almost touches my coil again tho. Man Im glad I dont have smog here. Id be screwed. I would have to sell my car. No cat, A.I.R, nothing....
Old Aug 3, 2002 | 12:31 AM
vrooom305's Avatar
is it emissions legal?
i have a random technology catalytic converter and an open k&n air intake. will this pass emmissions in washington or any other state?
Old Aug 3, 2002 | 10:22 AM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
there is no need to replace your stock aircleaner for smog inspection... as long as you relocate your IAC to the new base. The thermac on your old aircleaner has nothing to do with smog. It just helps the engine warm up quicker in cold weather.
Old Aug 3, 2002 | 12:04 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
In California you have to leave all Original equipment smog devices on unless they have a C.A.R.B. (california air resource board) certification number. This includes the stock air cleaner assembly. The vehicle won't pass the Visual inspection with it off.
Old Aug 4, 2002 | 10:04 AM
Snowdog 91 Formula's Avatar
A good high-performance shop will have the non-drop base for your air cleaner that will fit your K&N perfectly. Figure on about $10 for one.
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
NiG
Sep 7, 2015 11:25 PM
Billy Decker
Sep 4, 2015 03:46 PM
luvofjah
Sep 3, 2015 07:08 PM
