strang open element problem?
Old Aug 15, 2002 | 10:35 PM
Garett92Z's Avatar
Hey guys,
My friend has an 88 Camaro convertible, it's 305 TBI... now he doesn't know much about modifications or anything so I pointed him to the Ultimate TBI articles.
Now he has the car running great wants to do the TBI open element. He already went out and bought the K&N filter for the stock housing (I believe 14 x 3")
Is there a part number he can buy the non-drop base thing for it so he can use the filter he has?
the parts store isn't helping him at all and everyone's telling him he has to buy a kit? if he does have to buy a kit, where/part# and how much?
thanks a million guys,
Old Aug 15, 2002 | 10:58 PM
gordo's Avatar
I bought a mr. gasket cheapo air cleaner for about $25 and punched out the opening to install the crankcase tube and drilled a hole for the( I don't know) sensor. This set-up did amazing things to my car as for power.
Old Aug 15, 2002 | 11:42 PM
deadtrend1's Avatar
I dont think the stock filter fits in a open element casing. I belive i tried it for ----s and giggles awhile ago and it didnt work. They are cheap enough and common to find.
Old Aug 16, 2002 | 01:56 AM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Yeah, you can pick up a Mr. Gasket chrome open element at Advance for $16.99 I believe. No kit needed. Just relocate the air temperature sensor to the flat base and you're good to go. The stock aircleaner does not take a 14X3 element, you will have to return the one you bought.
Old Aug 20, 2002 | 03:01 PM
RSCamaroGuy92's Avatar
Car: 92 Camaro RS
Engine: 355 94 p/u motor
Transmission: 700R4 With TCI kit
stock isn't 14"x3"
I measure my stock one a while back, it was wierd(like 12" or 13" by 2"). I was going to get a K&N open element top, but they don't make one in a STOCK size.
Old Aug 20, 2002 | 04:23 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Moroso #66210.
Chrome 11-1/2"x2-3/8" Air Cleaner.
Have one on my TBI S10 Blazer (used to be on my RS)
This one will fit the stock-size K&N Element (but doesn't have a flat bottom, so you'll still need a spacer)
Summit has 'em for 39.95 (MOR-66210)
-Rich-
Old Aug 20, 2002 | 08:14 PM
v8powr's Avatar
check my sig...thats the one i have....works fine in my case. Bought it at advance for $27 + tax.
Old Aug 23, 2002 | 06:07 AM
CamaroEFI's Avatar
you don' need a kit. i did the open air setup to my 91 TBI. its very simple. all you need is a non-drop base air filter housing and probably a drill. i took the crankcase tube and turned it 180 degrees (make sure you leave the breather filter in it). i used the drill to drill a hole in the base to put the air temp. sensor in and that was it. im going to make a cold air intake like the one in the Ultimate TBI mods. because the hot air from the engine bay and outside really does kill the car. you're in canada so you don't have to worry about that.
Old Aug 23, 2002 | 08:56 AM
MuttandJeff's Avatar
Engine: 5.0 TBI
Transmission: 700R4 Auto
Snuf
Go to this site and follow the directions step-by-step. Its probably the best instructions you'lll ever find.
Snflupigus' Open Filter Aircleaner Page
Brinkkl2000
Aug 4, 2018 08:29 AM
Infested
May 22, 2018 11:56 PM
red90IROCls1
Aug 25, 2015 06:56 AM
wruiz
Aug 13, 2015 09:07 PM
