Stupid Hypercrap chip
Old Sep 18, 2002 | 11:00 AM
vrooom305's Avatar
I bought my 91 Camaro RS 305 TBI from my cousin a few years back. He said that he put a Hypertech chip in the computer. However I think he put the wrong chip because the car is running like crap even after I brought into the shop for a tune up. Is it possible for my Camaro to run like crap if it had the wrong chip?
Old Sep 18, 2002 | 12:27 PM
JPrevost's Avatar
Car: 91 Red Sled
Yes, it's very possible that he's using an eprom not made for the 8746 ecm. There are LOTS of ecm's that use the similar c3 type ecm's and their eproms are physically the same.
Find out what the chip is, either e-bay it or through it away and get a stock eprom in (if you're running stock) then advance the base timing until you get knock counts (winaldl works great, so does the expensive tools) then back off the timing 2 degrees.
Old Sep 18, 2002 | 02:34 PM
Jokerman's Avatar
Engine: slowtacular L03 305
Transmission: slushem 700r4
Hey while you are talking about advanceing the timeing whats a generaly safe and decent # of degrees that can be advanced on most cars? Just wondering since i am always looking for something to do in my spare time. (which currently doesn't exsist with college move in comming up in 2 weeks)
Old Sep 18, 2002 | 03:56 PM
vrooom305's Avatar
thanks for help...but there is another problem...
I do not have the stock chip and I tried to order one from the dealer but they have three different chips 1)Federal Emissions 2) California Emissions 3)no specific Emissions. Is there a way that I can find out which is the right chip?
Old Sep 18, 2002 | 04:07 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
On a non modified tbi engine, most people can advance base timing between 4*to 8*. I have mine at 6* advance. Be sure to use premium gasoline if you do this.
Old Sep 18, 2002 | 07:20 PM
JPrevost's Avatar
Car: 91 Red Sled
All the chips will work but you'd probably want the Fed emissions unless you're in Cali.
Old Sep 19, 2002 | 05:31 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
What the....
Hell are you talking about, 4-8 degrees from the stock adjustment????Of 4-8 degrees of base timing??? Stock BTDC timing on L03 TBI's is 10 degrees, 12 runs the best, and 14 is plenty of off the line performance but it pulls a bit off the top end, from my experience, 12 degrees of base timing runs optimal, and you should always run at least 89 octane anyway, these motors have 9.3:1 compression.
Old Sep 19, 2002 | 06:32 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Stock timing on an LO3 is 0 degrees. I ran 8 degrees when my engine was stock on 92 octane with no pinging.
Now I did the ol turn it till it pings and back it off a lil method because I was pissed at my trap speeds at the track. lol, way to be level headed Chuck.
Old Sep 19, 2002 | 08:33 PM
Jokerman's Avatar
Now i am slightly confuse since i have had to teach myself alot about cars on my own (tv, the net, books, other people, ect) so my knowledge has holes here and there. What does BTDC stand for exactly because its kind of confuseing me.
Old Sep 19, 2002 | 09:05 PM
Boxeat2469's Avatar
BTDC stands for before top dead center. It refers to the number of degrees before the piston is exactly at its highest point in the cylinder.
Old Sep 20, 2002 | 08:36 AM
Jokerman's Avatar
Makes mucho sense now thanks.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
