Bogging Down
Old Sep 23, 2002 | 10:24 PM
mylittlemule's Avatar
Car: 87 Wrangler
Engine: 355 TBI
Bogging Down
Thats the only way i know how to describe the sound and feeling in the motor when i go past a 1/4 throttle. She stumbles and makes some *** awful noise. She gets better when she warms up but it never goes away. I don't even know where to start with this problem. Any help would be great.
Old Sep 23, 2002 | 10:44 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Sounds like you're running rich. It may be really bad when it's cold because the ecm is adding even more fuel to warm up your engine. Check your fuel pressure, and maybe your TPS. Also try checking your wires, plugs, and cap and rotor-ignaition has been a major source for many of my problems(burnt wires, mechanics not hooking wires back up after working on car).
Old Sep 23, 2002 | 11:36 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
advance your timeing
Old Sep 24, 2002 | 09:41 PM
Car: 87 Wrangler
Engine: 355 TBI
my tranny is running like dog poo. would this affect my motor? it runs great in park, but when i put in drive is when i have all the problems.
Old Sep 25, 2002 | 04:36 PM
rad8tion's Avatar
Car: 92 RS Convertable
Engine: RAMJET 350
Transmission: G-FORCE T-5
check your cat
I had a cloged cat on my '98 S-10 and at part throttle the engine was fine but when I got past 1/3 throttle it just wouldn't rev worth a damm. Turns out the front ceramic block in the cat had rotated 90 deg and was all but blocking flow. now you can see right through my cat and it runs great(except for that pesky service encine light)
Ryan
Old Sep 26, 2002 | 02:53 PM
Car: 87 Wrangler
Engine: 355 TBI
Well that seemed like a reasonable idea but i don't have cats. Just a couple of flows. I talked to a buddy and he thinks i need to fix the tranny before i do anything else. And i agree, it runs like crap. It leaks all over the place. timing and fuel pressure are going to b ewhat i look at after i rebuild the tranny. Any suggestions on what type of rebuild kit and shift kit i should use?
Old Sep 26, 2002 | 03:17 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Get the whole 9 yards kit from Pro-built automatics. http://www.pro-built.net/ if you know a competent trans mechanic. Otherwise just get the trans from probuilt and you will be a happy camper.
Old Sep 26, 2002 | 03:42 PM
Engine: LO3;383tpi
removing or gutting a cat in thirdgens should not cause the servive engine soon light to come on.
Old Sep 26, 2002 | 03:45 PM
Car: 89 Camaro RS
Engine: 355 TBI
he was talking about the ses light on his 98 s10
Old Sep 26, 2002 | 04:19 PM
Engine: LO3;383tpi
D'oh! My bad
pjsparts
Oct 29, 2025 06:39 PM
RedLeader289
May 28, 2019 01:47 PM
Infested
May 22, 2018 11:56 PM
Grant2k
Apr 4, 2016 08:21 AM
middian
Sep 5, 2015 01:42 AM
