List what I need for a 305tbi-350tbi swap.
Old Oct 7, 2002 | 08:40 PM
TBI305Camaro's Avatar
Ok for this swap I will need the following
350 knock sensor
350 injectors
350 comp/chip
What else will I need for the time being. Im ona budget and since the 305 went south I need a motor soon and I will only have about 2000 to throw in for a motor. Please let me know if I missed anything.
BTW im probably going to get a lo5 long block and put everything I have including the lt1 cam in it. Then when income tax time comes ill probably put heads on it.
Old Oct 7, 2002 | 09:01 PM
myinvestedagony's Avatar
You'll need the 350 knock sensor, esc module and injectors.
Injectors:AC/Delco #17112493
Knock Sensor: AC/Delco # 10456288
ESC Module: AC/Delco # 16128261
if you plan to run a larger cam you might want to think about an adjustable fuel pressure regulator and another good idea is the Holley TBI unit. when you go to the holley website it is actually listed for use on 350 tbi trucks but it is the exact same unit, and all the electronics bolt right up, it is a good upgrade for the price. heard nothing but good things about it. I dont know what kind of price you are looking at but I know a machine shop who offers amazing deals. starting price on a 350 is $995 for a long block and to upgrade parts you just pay the difference for the upgrade... it is in Indianapolis, IN so you would have to have it freighted but let me know if you want the # I dont know what kind of prices you have got so far, I understand you money dilemma though,
myinvestedagony
Old Oct 7, 2002 | 09:22 PM
Yeah man give me the number. I thought there was a few other things i needed. Im just gonna do the ultimate TBI mods and use my edelbrock TBI intake for now. I do need a vaccum advanced fuel pressure reg since ill be going with a lt1 cam...(very mild but i already have it and the lo5 cam is worse than the lo3 so...) Im gonna have to have a motor crated in anyways so ill give your shop a call.
Im about tempted to take out a student loan for this....3% interest plus i dont have to pay it back for awhile
Old Oct 7, 2002 | 09:25 PM
I will try and get you the number tomorrow my dad actually had it...... and you might wanna look into a normal 4 barrel carb. intake they are cheaper and typically work better, all you need is a tbi adapter plate also available from holley.
Old Oct 7, 2002 | 09:32 PM
I already have a edelbrock TBI intake on my 305. No point of changing now...i may eventually go carb or with a holley 670tbi but not until money allows.
Old Oct 7, 2002 | 11:06 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
Get you a gm moter from www.paceparts.com they have a moter there that is for a tbi caprice if you add the lt4 cam to it then it will have over 300 horsepower and it is only 1595.40. THe part number is 12513151. let me know if you need anymore info
Old Oct 8, 2002 | 01:28 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
i plan on getting the Lo5 too. but i already have a LT1 cam. how much better is the LT4 and can it be used with the stock springs on that engine. i wont be getting heads for a while.
also what is the esc module.
Old Oct 8, 2002 | 05:59 AM
TheJoeY88's Avatar
already did swap
i did the 305 to 350 swap
went with a stock non-roller post 86 small block chevy
did the knock sensor and module change
went witht he holley 670 and intake, went with a 110degree Comp Cam
the thing is, do i need to change the ECS to make a custom chip, or can i use the ECS that came in the car stock?
just curious since you are telling this guy to get a new ECS
thanks
Joe
Old Oct 8, 2002 | 06:09 AM
TheJoeY88's Avatar
stupid me
never mind, read another post, i get the ECS and the actual computer for the car mixed up
still learning this newer computer stuff
my 78 TA is much easier to tune
Joe
Old Oct 8, 2002 | 02:44 PM
I hear the lt4 hotcam is NOT tbi friendly. The computer will hate it. I already have a lt1 cam so I will probably just use that since im digging for cash right now. I will check out paceparts and see what they have.
Old Oct 8, 2002 | 02:49 PM
Car: 89 Camaro RS
Engine: 355 TBI
It's not the hotcam kit it just the lt4 cam and your going have to burn a custom chip any way you go.
Old Oct 10, 2002 | 10:41 AM
component machine
hey man sorry it took me so long to get you number for the machine shop, it is called component machine it is in Indianapolis, IN and all the guys are really easy to work with just tell them what you have and what you want to do and they will help you out, my dad has used several of there engines before in direct marine replacements, and also a personal vehicle here ya go
1-800-878-1631
Old Oct 16, 2002 | 11:39 AM
you wouldnt happen to know the parts # for the cop car injectors would you? Im going to go with the cop car route for now...should be very easy to get running with TBI for now until later when I switch to carb or whatever.
Old Oct 16, 2002 | 11:46 AM
No I dont know what the part numbers are but what is the "cop car route" anyway?
Old Oct 16, 2002 | 12:04 PM
Well the engine im getting from paceparts is the lo5 version used in the caprice cop cars. They had a tad more HP because they have a l98 cam instead of the lo5 cam. They also have alittle higher compression at 9.6:1. The injectors are alittle larger and the chip doesn't have a speed limiter on it.
$750 L98
Feb 1, 2025 02:25 PM
Lbibb
May 5, 2016 12:00 AM
okfoz
Oct 13, 2015 02:19 PM
usafirebird
Sep 29, 2015 11:58 PM
Dragonsys
Sep 25, 2015 03:51 PM
