ok need manifold help
Old Oct 26, 2002 | 01:58 AM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
please no "search answers i looked and for some reason maybe my error i could find this exact topic although i'm sure its been covered
i'm considering a performer maniflod with tbi adapter or an edelbrock tbi intake which is the better or if equal more economical intake.
or if someone could suggest a better option. that will be <B>close</B> to emissions legal or shall i say easy to cover up.
A little help please
Old Oct 26, 2002 | 04:25 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
I don't know what the rest of your combo is, but I have ran both types of manifolds and I think most people would be better off with the performer TBI manifold. Its alot easier to install, and probably better for all around driving. Right now I am running a preformer RPM and it takes more then twice as long for the manifold to heat up enough for the motor to run right in cold weather. I ran a performer tbi last winter and within about two miles of driving it was fine. This is because there is a water jacket arround the plenum and on the underneath side of the manifold.
If your car is used mostly for racing go with a four barrel manifold. If your car is not heavily modified I believe you are better off with the performer TBI.
Old Oct 26, 2002 | 11:06 PM
NJ SPEEDER's Avatar
you can adapt any performer manifodl that has an egr on it and still meet emissions eassily. the nice thing abotu the performer tbi si that it is a direct bolt on, no adapting needed.
later
tim
Old Oct 27, 2002 | 12:28 AM
TBI305Camaro's Avatar
go with a holley manifold and adapter. I bought a street dominator manifold and its very nice. Looks much better than my edelbrock TBI. plus it would be cheaper to run the holley manifold + adapter plate. I think the carb manifolds flow better plus if you ever gonna change over to carb or whatever youd already have the intake,
Old Oct 28, 2002 | 08:36 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Hey TB305Camaro....I am finially going to pull the trigger and do the intake swap on mine.
Can I ask you some questions as to what you purchased (part numbers if you have em), what you had modded on your car, any issues with installation and what were your end results with the intake???
Thanks,
Much appreciated
Old Oct 28, 2002 | 08:51 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I have the edel performer and adapter and i like it. The only complant i have is the increased maniflod volume means i have to crank it a little futher to get fuel down the runners and into the cyls. for it to start but thats all.
Old Oct 28, 2002 | 09:07 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
dimented24x7 anychance you have a part number and can you give me a quick blurb on what you have done to your car??
Old Oct 28, 2002 | 10:54 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I have the performer rpm plus adaptor. Too much manifold for my application, shoulda went with the performer. Oh well live and learn. The hardest thing to figure out are the vacuum lines. I ended up getting a thing with a nipple on top for the brakes then the same thing had another vacuum port to run the heater vacuum line control off of and whatever the third vacuum line ran to connected to it too. Kinda fun. You can sort of see what Im talking about here.
db057
Jan 10, 2020 08:55 PM
sailtexas186548
Feb 17, 2017 03:07 PM
Chas91Z28
Oct 22, 2015 10:12 AM
86CamaroDan
Sep 29, 2015 10:08 PM
