Why is my rebuilt L03 running so wierd?
Old Nov 9, 2002 | 12:23 AM
RallySport92RS's Avatar
hey everyone, I just got my engine rebuilt with this work done:
LT1 cam,
Iroc heads, port and polished
30 over
raised compression
and 3 inch exhaust
when I touch the gas i have less low end torque then my moms saturn, and when i am moving and touch the gas about quarter throttle it bogs down. like the rpms shoot down, then up, then down, then back up and it all feels really jerky
any idea what could be wrong? My dad thinks it could be a couple valves to tight or loose.
Old Nov 9, 2002 | 10:20 AM
TBI305Camaro's Avatar
you probably need a chip to...that could be the main problem.
Old Nov 9, 2002 | 11:58 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Could be a bunch of things...how much did you raise the compression? How about the timing? TBI305Camao is probably right with the chip problem cause the stock chip still thinks it's running the old combo. Especially what that cam.
Old Nov 9, 2002 | 01:04 PM
the timing is at 10 degrees advance. and they said they took twenty thousanths of an inch off of the heads. I dont know what the raises the compression to?
If I need a chip where do I go to get a custom one burnt and how much do they usually cost?
Old Nov 9, 2002 | 01:35 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
When I needed a chip, I just posted a wanted ad in the classified section in this site and found someone with a similiar setup as mine to burn me a chip for 50 bucks. I would suggests trying to find someone who has experience in burning chips for a setup similar to yours.
Old Nov 9, 2002 | 03:52 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
yer stock chip aint gona cut it there bud. youre most likely going lean and then rich too rapidly = ecm cant figure anything out.
need a custom chip or go carb.
Old Nov 9, 2002 | 06:04 PM
deadtrend1's Avatar
Originally posted by snflupigus
.......or go carb.
BLASHPHEMY!!!!!!!! ::slap:: LOL
j/k snuff
But yea ... 99.9999999% of my sources say custom chip
Old Nov 9, 2002 | 07:05 PM
do you guys think my valves could be causing some of this problem too??
Old Nov 10, 2002 | 12:39 AM
i went carb...cant tell you if it was worth it or not yet because it wont stay running. Not the carbs fault tho...fuel pump wont stay on. I think I got rid of way to many sensors and it freaked the ECM out completly.
Old Nov 10, 2002 | 11:08 AM
JR305's Avatar
When I did the head/cam install my valves were too tight and loosening them up improved the idle and how it ran. Under your setup the car should be pretty drivable even with the stock chip. I was running on the stock auto chip with my car for like 2 months.
When is it bogging down? Because with the bigger cam you should looses some low end torque.
Old Nov 10, 2002 | 11:17 AM
It bogs when i'm in the 1000-2000 rpm range. When I touch the gas it will shake and bounce until it hits 2000 rpm's, then it smoothes out and is fine. Also, when i'm at a stop light it shakes slightly too.
It's just the LT1 cam and I was told that will work fine with the car so I don't think it is the cam but maybe it could be?
Old Nov 10, 2002 | 11:30 AM
JR305's Avatar
That sounds familiar. I think some of your valves are a bit too tight. Also that cam under the stock chip should be running a little rich under 1500 rpm. So that could be another reason but I would defiantly go back a recheck your valves.
Old Nov 10, 2002 | 11:36 AM
Ya before I had the rebuild done my only engine mod was the cam and my mechanic couldn't believe how rich it was running just from the smell and checking the tail pipes.
Does anyone know if I just have to tell someone what my mods are to get myself a chip burned? Or do I have to know all of the specs?
I know the specs to the cam and my exhaust. But the heads and compression im not to sure what the specs are so will this be a big problem?
Old Nov 10, 2002 | 11:44 AM
JR305's Avatar
You should just do the chip yourself, it’s not near as hard as everyone seems to think.
But if you are going to pay some one to burn a chip for you, you need to at least know cam specs, compression, injector size, fuel pressure, and exhaust.
Old Nov 10, 2002 | 05:35 PM
snflupigus's Avatar
all those things are easy to find out.
you will want to adjust fuel, timing, and definately idle air motor steps.
Old Nov 11, 2002 | 04:50 PM
turns out that when the engine was being installed, they dropped 3 of the plugs and they had cracked. The valves were off slightly too and those were adjusted. I can smell gas so that means it is still running to rich right?
I will probably get a chip next week so hopefully that will help
Old Nov 11, 2002 | 06:20 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Check your Detent cable and make sure teh tranny shifts right.
Old Nov 11, 2002 | 08:25 PM
where is that located??
Jake_92RS
Jan 28, 2020 10:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
backtothe80s
Sep 5, 2015 12:39 AM
KO1
Aug 31, 2015 06:31 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
