Adj. press. regulator
Car: 91 RS Camaro
Engine: 305 TBI
Can anyone tell me the benefits of using an adj. press. regulator? The pressure reads 12psi just before entering the TBI. My stock pump puts out 9-13psi, so what is the use of adjusting pressure? I am already showing 12. Know what I mean?
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
If your engine's modified (bigger cam, heads, etc) you can fine tune the fuel mixture with pressure.A chip is needed to change the injector duty-cycle, but for instance, if it runs close to stoich at idle-4000, but leans out above that, you can compensate a little by adding fuel pressure. Of course this will also make it a little rich at the bottom end, but it's a better compromise than running dangerously lean higher up.
I'm running about 18 psi.
-Rich-
-Rich-
If you decide to convert, it isn't difficult:
TBI AFPR Conversion.pdf
(You'll need Adobe Acrobat Reader to view/print the file.)
Car: 91 RS Camaro
Engine: 305 TBI
Well the thing is, is that I already have a adj. press. regulator I just haven't put it on because it seems mute. My fuel pump can only put out 13 and my pressure reading is now 12 so what I am thinking is that I can't adjust what isn't there. Does that make sense?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I have the vacuum adjustable regulator and I am very happy with it. The way I have it set i think i am like 11psi at idle and maybe 15 at WOT.
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
yeah, the vacuum one is definitely the way to go. i have it on mine, and it is SWEET!!
i should have some info about it on my site in my signature. if you need anything else, let me know. i have a ton of pics of the installation.
-brian
-brian
Car: 91 RS Camaro
Engine: 305 TBI
Thanks for the info Brian and nice work on your car by the way. Looks good. I do have a question about it though. How did you mount your msd box where it is? Do you now have no heater? Can you do that and still keep your heater? Thanks.
Car: 91 Z28
Engine: LB9
Transmission: auto
Car: 1991 Camaro RS
Originally posted by iroczrockz
Doesn't that vacuum line restrict air flow?
-brian
Car: 91 RS Camaro
Engine: 305 TBI
Ok look forward to seeing those pics. Hey I am still interested in seeing what you had to do to the firewall around the a/c inlet and heater motor. That looks good I would like to try that if it dosen't hurt anything. Thanks
Car: 1991 Camaro RS
ok...i posted the pics on my web site.
go to z28boy.cz28.com , and go to "general tech" on the table of contents on the left side. then, click on the link to the GM AFPR installation.
there should be some stuff there that may help out.
any questions..just ask.
-brian
-brian
Car: '90 RS
Engine: 377 LSX
Pablo
I am going to do something like that this winter. That pic is not actually of my car but my setup is the exact same in the exact same route/location with the exact same parts. I have the ultimate TBI mods which help considerably and the vacuum line is pretty much out of the way of the bore. I will get some pics soon.
Car: 1991 Camaro RS
no, i dont have heat (at all). i only have the car on the road from may 1st to october 1st, so i really dont need it.
i removed the entire blower motor and everything, so all it is is firewall there. it leaves you with two holes in the firewall, so i made a "cover" for one, and just kinda left the other. if you want, i will get some pics posted. actually, i will probably post them on my site anyways. ill let you know when i get them on there.
mounting the MSD box was easy and pretty straight forward. i dont like using screws, so i just drilled some holes and went out and bought some nuts and bolts, and was all set.
-brian
gixxer92
May 18, 2017 11:20 AM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
