350 engine questions
Old Dec 1, 2002 | 11:12 PM
SuperTrans Man's Avatar
Car: Camaro
Engine: 5.slow
Transmission: 5 speed manual
planing to get a new 350 not for a while mind u but when i do i want to be ready, and i plan to toss on a tbi system, i was plaining to do this with my 305 but might as well go 350 what do u guys think about this http://www.sdpc2000.com/cart.asp?act...id=128&pid=110 yay or nahh ??
Old Dec 2, 2002 | 03:28 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Man, I tell you what I just switched from a 305 to a 350 in my RS camaro and it has TBI. I was starving the 350 for a while because I had to run it on the stock 305 set up until I could get a new TBI unit and injectors. I still need a chip burned and it should be about complete. It runs good though. I haven't had a chance to take it to a track but I can tell the difference. My 350 came from scoggin dickey chevrolet and it is suppose to have 300hp.( I am assuming that is at the flywheel.)That motor was made specifically for TBI cars and trucks.
Old Dec 2, 2002 | 07:16 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
You should be able to find a 350 that makes more HP and Tq than that one. If you're doing a REALLY budget minded build up or just need a replacement, than that's the one to go with....but for peformance, you should be able to do better than 249 HP/ 304lb/ft. Actually, I believe RICH92RS got one from Pace I think that puts out 300 HP and 370lb/ft....I think those are the numbers. You could PM him, and he should be able to help you. I have the part numbers to do the exact switch that he did, but not on this computer.
One more thing, do you have to be emissions legal?
-The Gunny
Old Dec 2, 2002 | 09:45 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I bought the 300hp 350 crate from goautocenter.com.
It's a Caprice 350 short block with tpi heads and a Crane Compucam 2030 hydraulic roller (their recommendation for tbi).
It made 317 hp @4500 and 399 ft/lbs @ 2500 (flywheel)
with SLP 1-5/8" headers, 3" cat, Flowmaster Cat-back, Turbo City throttle body and AFPR and Edelbrock Performer TBI Intake.
Also custom chip from Ed Wright @ Fastchip.com.
It passes smog in CA as a 305 with the stock air cleaner on (for the visual inspection).
-Rich-
Old Dec 2, 2002 | 10:16 AM
Car: 91 RS
Engine: 350 TBI
RICH92RS350:
That cam you have....is that the one that they supplied, or did you buy that seperately? Also, I thought you had the Holley unit sitting on top of your motor?
Old Dec 2, 2002 | 10:42 AM
Car: 92 Camaro RS
It's the cam that came in the motor.
(Optional tbi cam listed towards the bottom of the page)
http://www.goautocenter.com/300hp_tpi_1987-89.htm
I didn't get the Holley Throttle body because at the time, I was getting info that their injectors didn't tolerate increased fuel pressure very well. I understand that is no longer a problem as they don't use that type of injector any more.
If I was to do it again, I'd use the Holley.
The Turbo City unit is nice, but the bottom was not flat and I had a vacuum leak initially. Since the car's my daily driver, I didn't send it back, I just took it off and used a steel block with sandpaper to get it flat and put it back on.
For the money, It should have been flat to begin with.
-Rich-
Old Dec 2, 2002 | 11:31 PM
Car: Camaro
Engine: 5.slow
yes it has to be emssions legal (damn it!!!) and yea im doing it on a prity tight buget but i want something to build off of so i guess i should shop around for something with a higher hp/torque ratting?? how much would one be and i kinda want a big block not a short one but that doenst mean i wont go short block
Old Dec 3, 2002 | 07:15 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Don't go with the older technology block. Go with the newer style that has the roller cam. http://www.sdpc2000.com/cart.asp?act...id=128&pid=105
Then you will have a nice base to build off of.
Or go with a nice new L98 shortblock. http://www.sdpc2000.com/cart.asp?act...id=514&pid=620
And go ahead and put some better heads and cam in to begin with. You should still be able to finish the job for around 2k.
Then there is the always popular.
http://www.sdpc2000.com/cart.asp?act...id=120&pid=115
Old Dec 3, 2002 | 11:47 AM
vjo90RS8's Avatar
Car: 2002 Z28
paceparts features the L05 Caprice engine in their new catalog..
"This motor incorporates a factory hydraulic roller cam, a nodular iron crankshaft, hypereutectic pistons, PM connecting rods, torsional damper and cast iron 64cc heads."
This is the engine im going to get when i do my swap in the summer.
Old Dec 3, 2002 | 12:44 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Speaking of Hypereutectic pistons: Does anyone know if you can use Nitrous with those pistons?
Old Dec 3, 2002 | 02:44 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
-Rich-
you ran the engine on the dyno, with the whole exhaust system on?
Old Dec 4, 2002 | 09:52 AM
Car: 92 Camaro RS
On the dyno, it had the headers, Y-pipe and cat that are on the car. Ran a regular two-chamber flowmaster muffler and a straight piece of 3" tube, 3' long (not the muffler on the car).
Also had the air pump, water pump and power steering pump hooked up, though the steering pump wasn't connected to anything. Didn't connect dyno's exhaust thermocouples. Mainly ran it in over there to check for leaks, a luxury I no longer have , as my friend doesn't work there any more.
-Rich-
Old Dec 4, 2002 | 09:55 AM
Car: 92 Camaro RS
I've been told not to run more than a 50 or 75 shot on the hypereutectic pistons, though I don't personally have much experience with N20. If you plan on running a 150+ shot, I'd definitely invest in some forged pistons.
-Rich-
Old Dec 4, 2002 | 07:15 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Thanks, I don't even know if 50 shot is worth the money. It just seems that most people are using 150 shot and knocking off up to 2 sec. on their times. That is pretty impressive. I don't know that much about N2O myself though.
Old Dec 4, 2002 | 10:32 PM
Car: Camaro
Engine: 5.slow
well ultimitly i want to put a 100+ shot in so what would the best way to go?
Old Dec 4, 2002 | 10:39 PM
Car: Camaro
Engine: 5.slow
Old Dec 4, 2002 | 10:54 PM
Dan94GT's Avatar
100 shot should be alright on hypers. if the fuel system is up to it and you tune it good.
My year of mustang has hyper pistons from the factory. (92-earlier have forged) and their are a lot of people I know online that run 150 shots and big blowers. One guy ran 11psI ontop of a nice HCI on the stock shortblock and finally broke everything. made over 600hp and ran 11s if I recall.
Im going w/ hypers in the 327 or 350 Im about to start building.
for those trying to buy engines. Ever seen PAW? they have some good deals on entire shortblock/longblock kits.
Old Dec 4, 2002 | 11:35 PM
Car: Camaro
Engine: 5.slow
but again need something cheep around $1500 cuase im kinda runnin on empty now need some extra funds!!
Old Dec 5, 2002 | 12:25 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
I agree with the P.A.W. thing. They do have some good buys. They had some good flat top forged pistons at a resonable price when I built a 383 a few years ago.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
