problem with jumpin rpm's
Old Jan 10, 2003 | 09:28 PM
burnouts4ever's Avatar
when i am cruising for instance say 25 mph with steady throttle my rpms will jump for say 2,000 rpm to like 2,100 rpm and keep jumping up and down like wah wah wah, until i either give more gas or let off what do you think the problem may be?
Old Jan 10, 2003 | 09:46 PM
sometimes when i get gas it runs better for maybe a day or so then it wont anymore.
Old Jan 10, 2003 | 11:12 PM
heck my 4.1 regal had better throttle response lol
Old Jan 10, 2003 | 11:22 PM
kills me when i first got the car it had great throttle response what coulda went wrong ....... I got it 5 months ago.
Old Jan 11, 2003 | 07:30 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Does it do it cruising on the freeway at 60 mph as well? I know a flakey TPS sensor does that. The computer sees the fluctuations in the TPS sensor readings and starts adjusting fuel and such causing a jerky ride. Only way to test TPS sensor is with multimeter and test voltage as you open and close the throttle and look for unusual voltage changes.
Old Jan 12, 2003 | 12:23 PM
billdawg23's Avatar
well the rpm thing can happen whenever, but for some reason i dont think the car is getting enough gasoline.
Old Jan 12, 2003 | 07:51 PM
JPrevost's Avatar
Car: 91 Red Sled
Fuel pump, fuel filter. Those come to mind.
Old Jan 13, 2003 | 01:19 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
when this happened to me it was a burned spark plug wire, I had a stock exhaust on it at the time, so I couldn't hear the miss.
Old Jan 13, 2003 | 04:09 PM
well i replaced the cap and rotor, i think it helped it out, now i gotta do the coil. I am also going to do the fuel filter.
Old Jan 14, 2003 | 01:02 PM
replaced cts, problem fixed
355tpipickup
Aug 27, 2015 08:13 AM
Regal105
Aug 23, 2015 03:45 PM
forstral
Aug 19, 2015 03:20 PM
hokis
Aug 9, 2015 03:57 PM
