TBI Performance
Old Feb 24, 2003 | 02:42 PM
MustangMuncher's Avatar
Car: 89 Camaro
Engine: 355
Transmission: Coan rebuilt TH700R-4
TBI Performance
Alright, I have a 355 motor I built and have a chip to go along with it. It runs fine but I want more power from the TBI. I installed 350 injectors and was wondering if anyone knew if Turbo Citys injector lift kit works well, if a TBI swirl spacer would be practical, or a tornado type air swirl, and if cold air induction be managable since no one makes it for our gen years. I am just wondering as to what ideas I could do to make it breath a little better, other than switching to a carb. Thanks.
Old Feb 24, 2003 | 03:12 PM
vjo90RS8's Avatar
Car: 2002 Z28
I would just install an open element
if you dont want to spend $20 for an injector spacer, you can just go to your local parts store and buy 2 injector pod gaskets (1/8inch each), it would be the same height as the injector spacer.
As for the TBI spacer, I am going to be getting a 1/2" spacer (biggest you should go unless you want to mess with you linkage) but i wouldnt spend more that 30 bucks for one.
Old Feb 24, 2003 | 04:24 PM
NJ SPEEDER's Avatar
check otu teh tech articles for the ultimate tbi mods before you go spending any money. please tell us the rest of the work that you have into the car, was teh chip burned from a data log or from a spec sheet?
later
tim
Old Feb 25, 2003 | 05:54 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
you mean you can put two injector pod gaskets on the throttle body and give it more power?
Old Feb 25, 2003 | 06:10 PM
NJ SPEEDER's Avatar
that is all taht the injector spacer does, it raises teh injector pod up slightly to allow more air to pass by. tbi has a lot fo power "stored" in it because gm didn't optimize any part of teh system from teh factory. it is not uncommon for people to gain noticable performance from just from free mods mentioned in teh tech articles.
later
tim
Old Feb 25, 2003 | 10:34 PM
Car: 89 Camaro
Engine: 355
The chip
The chip was custom burned to the motor with a tech sheet I sent in they burned it from the information. It has the L31 Vortec heads, edelbrock short headers and cat back flowmaster. The cam is the biggest that will allow with the upgraded spring lift kit installed on the heads. There is really too much more to list on what I have done, but the car has 162,000 miles and not one of them belong to that car besides the sheet metal on it.
Old Feb 25, 2003 | 10:36 PM
Car: 89 Camaro
Engine: 355
cont.
is there anything more you can tell me about this throttle body? and if you could please inform me of the tech articles you are talking about! thanks
Old Feb 26, 2003 | 01:41 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
If you cant list everything you have done to your car then we cant help you. We need this info. no matter how small, or how long it take's to write it on here. Just make a sig once and then you never have to write this info again.
Old Feb 26, 2003 | 07:20 PM
NJ SPEEDER's Avatar
Re: The chip
this could be the answer. form a sheet of paper a person coudl get a general idea of what the fuel/spark needs of your car are, but for real performance you are gonna have to data log and have a real custom chip done. the only way tha tyou cna get the right chip form a sheet of paper is if a full chip was already developed from teh ground up for the exact same combo, and even then there woudl eb room for tweaking since no two motors turn out exactly the same.
for the tech articles jsut go to the front page of this site and hit th etech articles link. look at teh ultimate tbi mods. it is a 2 part thing. also check out the diy afpr for tbi. all the mods listed are easy and free/cheap.
later
tim
Old Feb 27, 2003 | 10:19 PM
Car: 89 Camaro
Engine: 355
Thanks for all your help I appreciate it guys!
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
scottmoyer
Sep 7, 2015 07:06 PM
