spring/summer plans
Old Mar 7, 2003 | 11:53 PM
burnouts4ever's Avatar
spring/summer plans
Listed in order, a seven step program lol
1. Catalytic Converter
2. Already did open element, custom one to come soon possibly/ free mods ac delete/ as well.
3. 1 5/8 headers
4. 3.42 rearend gears/ transgo shift kit/ torque converter
5. Lt1 cam/ comp cams roller rocker arms/Edelbrock Performer TBI Intake
6. Edelbrock STB, Eibach Pro kit springs, lca’s
7. Custom Chip
Im debating what other weight reductions i should do, does anyone have any good ideas, should i sell my stereo system that is listed in my sig? tell me what you think thanks.
Old Mar 8, 2003 | 12:26 AM
BillD91RS's Avatar
Sounds like a solid plan. I didn't see heads anywhere on the list. Have you thought about those at all? As for weight reduction it all depends on what you want to do with the car. you can switch to manual steering, remove the spare tire and jack, remove back seats and belts, fiberglass hood. Just for starters.
Old Mar 8, 2003 | 12:48 AM
I want to get fash without the heads, if im not fast enough then i will do heads. I have got rid of my spare and jack, but now i have 2 12 inch subwoofers back there that weigh a bit.
Old Mar 12, 2003 | 11:04 AM
camaroguy2003's Avatar
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
Intake
Suspension
Slicks
Thats my plan for this summer
I think with those I should hit the 13s pretty easily.
Andrew
Old Mar 12, 2003 | 12:22 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Better heads
Bigger stall
That should put my into the low 13s.
Old Mar 12, 2003 | 01:48 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
heads/cam/intake (in progress) i have the heads now, and am working on porting!
customer prom (in progress) i have all my datalogging stuff working, i have everything except the program , as soon as i order that i am on my way.
gears/posi - this will probably happen fairly quickly just trying to descide on the battle plan for that.
suspension (always in progress with me )- i have ALOT of this done, so not top prority for me, i have a few misc. things to get still. i have everything people normaly do to the suspension done, what is left is some custom work and some really fine tuning.
i think that pretty much covers this spring/early summer. i hope to be going 13s and improve my handling even more.
BTW this is all happening on the car i drive to work EVERYDAY!
Old Mar 12, 2003 | 05:53 PM
deadtrend1's Avatar
Originally posted by brodyscamaro
Better heads
Bigger stall
So you decided the stall over the nitrous kit?
my plans are carb, not tbi related.
Old Mar 12, 2003 | 08:45 PM
you are gonna run carb on ur 305? i didnt think that was apart of the tbi car in the 13's?
Old Mar 12, 2003 | 09:20 PM
iroc22's Avatar
Re: spring/summer plans
Get a fiberglass Harwood hood. Either stock or a cowl induction.
Old Mar 12, 2003 | 10:36 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
The stock hood weighs 14 tons, no joke.
Old Mar 12, 2003 | 11:17 PM
deadtrend1's Avatar
No, its not for my firebird
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
Zell1luk
Sep 29, 2015 10:36 AM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
