How do I remove this bolt from my smog pump!!!
Old Mar 20, 2003 | 05:36 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The bottom one came right off and the top one is satan himself. I have tried everything. It is stripped beyond all hope so I drilled a slot into it to use a flathead screw driver but It just won't budge. Can I just cut around it with my dremel or can I drill it out. Here is a pick of the bolt that I am talking about.
Attached Thumbnails How do I remove this bolt from my smog pump!!!-mvc-010f.jpg
Old Mar 20, 2003 | 06:48 PM
deadtrend1's Avatar
i used a offset drill and drilled mine out and cut the bracket around it. Torx bits suck what can i say.
Old Mar 20, 2003 | 06:50 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I am about ready to do that but I wanted to keep the bracket in one piece. Oh well, I geuss I can always replace it if I were to ever put the stuff back on. I am pretty sure I can pass the sniffer without it (I have a cat). I don't have smog where the car is registered but may when I move after school.
Old Mar 20, 2003 | 10:45 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
I'd set the a/c compressor to the side if ya can and get at it with some vise-grips... spray some PB blaster in there too at 2-3 hour intervals for a day or so and I bet it'll turn loose. Whatever you do, DO NOT do any hot wrenching on it. Those acessory brackets are aluminum and, well, you get the idea.
Old Mar 20, 2003 | 11:11 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I am not sure what hot wrenching is but I am pretty sure that I am not doing that. Just drilling it out. I may try to get at it with vice grips.
Old Mar 20, 2003 | 11:28 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Just do like you originally thought. Get a dremel with a cutoff wheel and cut the head of the bolt off.
Old Mar 21, 2003 | 02:23 AM
1MEAN92RS's Avatar
Engine: LO3
Hot wrenching is where you use a torch to heat a nut or bolt that has siezed. Heating the nut or bolt will help to break it loose, but you cannot use this method where aluminum is involved. One of the problems with steel bolts in aluminum is that they expand and contract at diffent rates often causing the bolts to sieze (this is why you use copper anti-sieze compound on spark plugs that are going into aluminum heads). Even if you can twist the thing outta there, if it's siezed that badly by forcing it out half the threads are probably gonna come with it anyhow. Just cut the thing off flush with the pump and if you really want that bolt out, weld a nut onto the end of it and then use your ratchet on it.
Old Mar 21, 2003 | 08:30 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
If I cut it off flush will that be enough for the pump to slide out? Would I have to drill into it a bit to clear the bolt from the bracket?
Old Mar 21, 2003 | 09:47 AM
vwdave's Avatar
Make sure you use the right torx the first time, 2 of them will fit, a small one, and a big one. Thats a mistake alot of people make.
What I did.....This is a VW trick.
Get a big hammer and a chisel(sp) and hit the head of the bolt counter-clockwise. Eventually, it should break loose.
Old Mar 21, 2003 | 09:55 AM
1MEAN92RS's Avatar
Engine: LO3
An air chisel works great too. We had one when I worked at Lube Time to break loose drain plugs that were too tight. We called it "The Persuader"
Old Mar 21, 2003 | 09:56 AM
vwdave's Avatar
Usually when drain plugs are too tight, they internally strip the pan.
Old Mar 21, 2003 | 10:48 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Well I got it out. I took off the AC compressor and set it aside and was able to grab it with some vice grips. I did damage the bracket (trying to drill it out) but the threads are okay and can be reused if I ever put it back on. Thanks for all of your help. I am now trying to find a belt that will fit. I hear the 968K6 is the one to get. I had a 967K6 belt that was to short by a couple of inches.
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
