Anyone got a Holley throttle body?
Car: '86 IROC
Engine: 305 LG4 awaiting the crate Vortec 350
Anyone got this? i'm thinking of getting it i just want to know if anyone has had the great results that i would imagine
It says for truck but i don't see why it wouldn't work on our cars
TBI @ Jegs
thanks
...Conner
It says for truck but i don't see why it wouldn't work on our carsTBI @ Jegs
thanks
...Conner
From: working at a horse farm, gonna go to somerset county tech. inst. in january.
Car: 87 GMC sierra classic
Engine: fresh 350, minor mods (its been de-emissioned too)
Transmission: professionally re-built 700R4, REALLY hard shifts & bigger clutch packs
let us know how it goes, id like to know what the improvements are like.
it can be done by the way, my friend put one in his RS with a 350 crate engine
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
thelink that you posted is for the incorrect one. the one that you want is the 502-6.
like 25THRSS said..do a search and you will find a lot of info.
i also have some info on my site in my sig that you may want to check out.
good luck...
-Brian
good luck...
-Brian
Car: 89 Camaro RS
Engine: 355 TBI
Z28-Boy I just wanted to tell you that i have found your site very very helpful in working on my car and geting idea's for mod's for my RS. Thank's for making such a wonderful web-site.
Car: 1991 Camaro RS
there is a lot of projects i am working on right now with the car, and as they get finished up i will be posting all the info on the page.
thanks man.
-Brian
Car: '86 IROC
well i did a search and didn't find too much. z28 boy- i checked out your site and its definately got some good info on there man. but all i really wanna know is is that throttle body a good buy? and wouldn't i want the 502-5 because i have a 5.0 not 5.7 (i wish
) thanks
) thanks Trending Topics
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
What mods do you have to your car? I ran the 502-5 when my stock injectors took a dump. The unit is really nice, but you will run rich, very rich and your gains will only be in the upper rpm. If your car is near stock, it is not needed. Give a little more info on what you have, and I can tell you whatever you'd like to know about the Holley unit.
Car: 1991 Camaro RS
) thanks
) thanks -B
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
i have the 502-6 on a 350 and the thing is super rich i have to figur out how to lean it up a bit i looked for the fpr but there is a brass cap where i think it should be gerrr
Car: 1991 Camaro RS
-B
Engine: l98 and lo5
ahhh ok i didnt want to start drilling into stuff with out knowing exactly have any idea where i should start off as for psi i am thinking about 12
Car: 1991 Camaro RS
-B
Engine: LO3;383tpi
Pablo is 100% right. You need to burn your own chips. The 502-5 comes with the 57pph injectors, and even with all my mods and the fp regulator turned as low as it would go, I still ran very rich on the stock chip. My BLMs were probably 112-118 on average. It took a few times to get them remotely close to 128. So if you do go with the 502-6, keep in mind the 65 pph injectors and be prepared for chip tuning.
Engine: l98 and lo5
Originally posted by Pablo
Uh, did you read what he just wrote?
I suppose if you dont mind driving a gas guzzling stink bomb youll be fine
Engine: LO3;383tpi
he did not say if he put that 502-6 on a 305 or a 350 if it was on a 305 i can understand why it runs so rich and with mods wouldn't make it worse due to the fact that he is pulling lower vacuum at low rpms.
I am not ragging on the unit by any means, as she is going atop my 383. But on a daily driver 305, it is not needed.
Engine: l98 and lo5
sorry, brain fart
yes i agree on that my truck runs very rich when it is in open loop but it is alot better when it heats up. but it was running rich with the stock unit cold too. i think it has to due with the 212,786 miles of plowing towing and mud bogging
. i also agree that it is over kill for a stock 305. the new motor i am putting in, in a week, is a lo5 with a cam projection intake, headers and the truck already has full exhaust 3" to muffler then duel 2.5 out. this thing will pbly run like crap till i get it tuned. hop i don't screw it up. have to order a programmer.
. i also agree that it is over kill for a stock 305. the new motor i am putting in, in a week, is a lo5 with a cam projection intake, headers and the truck already has full exhaust 3" to muffler then duel 2.5 out. this thing will pbly run like crap till i get it tuned. hop i don't screw it up. have to order a programmer. Last edited by c4boom; Mar 21, 2003 at 01:35 PM.
Terrell351
Jun 13, 2021 01:13 PM
mdtoren
Aug 16, 2015 05:45 PM
