New chip leaner at lower RPM's
Old Mar 26, 2003 | 09:39 PM
CHEVYTOWN's Avatar
What should I expect?
I was told by several people that I was running rich in the lower RPM's...
The truck was launching descent with the old chip at part throttle/WOT. Theoretically, can I expect better performance?
I wouldn't ask this question, however, a broken rocker arm stud (that's been fixed) has bogged me down.
Ctown
Old Mar 27, 2003 | 12:12 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I'm not sure what you're asking exactly. But I can tell you, the closer you get your entire BLM table to 128, the better. I actually think running rich at lower rpm is more noticable than at high rpm, because it does cause the engine to bogg so much. You WILL launch (assuming you have traction) much better once you fix the problem, and should notice better gas milage, as most of your cruising is in that range. If you're not using winaldl, I highly recommend it, as it is an invaluable tool.
Old Mar 31, 2003 | 01:02 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
ok i keep seein winaldl all over the board but i have know idea where to buy one any suggestions?
Old Mar 31, 2003 | 03:04 PM
Nitroburn's Avatar
It's free and you can get it from here.....
http://www.winaldl.webhop.net/
You'll have to make your own ALDL Serial cable, but it's VERY easy and the parts cost no more than $10.
Old Mar 31, 2003 | 06:15 PM
Car: '88 GTA
Engine: L-98
ill need a laptop to do that though huh
Old Mar 31, 2003 | 07:04 PM
Nitroburn's Avatar
A Laptop or a desktop with a long cord. What you could do is make the cord upto a length of 100 feet long so that you could connect it to a desktop cmputer. RS-232 serial specifications states that serial transmissions are good to 100 feet.
Since the ECM on the car is the pushing side of the serial interface, I have no clue if it could push the voltage as far as the specications state, but hey, it's worth a try.
The cord I made is about 25' with no problems.
Old Mar 31, 2003 | 08:46 PM
steve8586iroc's Avatar
Find HITHERE cheap lap top on ebay or where ever you can find one or barrow one, you really need to data log as you're driving the car to get good info for tuning and burning chips..
Steve
Old Apr 1, 2003 | 11:06 AM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Try making your fuel pressure regulator adjustable. Then you will be able to turn down the fp. Get a fp gauge to go with it so you know what pressure your running.
Old Apr 1, 2003 | 11:26 AM
Car: '88 GTA
Engine: L-98
actually im waiting on a vacuum adjustable regulator from my local gm dealer ill probably install it this weekend then tune with my multimeter off of my o2 sensor... i know this wont be perfect but it will be alot better and healthier (for my motor) than the lean condition im running now
deracer
Apr 11, 2016 12:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
NBrehm
Aug 25, 2015 11:49 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
bdads
Aug 24, 2015 06:01 PM
