replaced intake, now other problems
i replaced my intake, it took a few days to do it, then what do you know i find out i have a leaky head gasket on the driver side rear corner
man this is a pain, could i have some advice on how to do this.... thanks
man this is a pain, could i have some advice on how to do this.... thanks Supreme Member
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
It is going to be a pain. You may as well swap cams now, as you will only need to remove a few more things. You will kick yourself in the butt later on if you don't. I've never replaced a head gasket, but I did have to rip my heads off my old engine and it is a pain. I hope you have a long breaker bar. A starting point would be a haynes or chiltons manual as far as help goes. After that, the motor swap board should be helpful in assisting you. Best of luck.
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Originally posted by burnouts4ever
my head gasket is leaking can i fix it without tearing it apart like with high temp rtv?
just shove some hi temp silly putty in the area where .....
No, you have to take the heads off, theres a lot of pressure in there that rtv would do no good. Hence one of the reasons head gaskets are metal.
Car: 1991 Camaro RS
Engine: 305 TBI
If you've gotta take a head off and replace a head gasket, now would be the time to go ahead in change the cam. You're already gonna have the intake off, distributor out, a head off, etc...you would be half way there. I've seen you post about some LB9 heads you were getting. This would be the best time to do all of it. I bet you would see a noticeable improvement too. Just my $.02. Good luck with it.
