BLM 108 and 11 PSI fuel pressure.
Old Apr 18, 2003 | 10:09 AM
BillD91RS's Avatar
OK. I have a blm of 108 at just about every throttle possition. I purchased a fuel pressure guage the other day and last night I measured 11 PSI fuel pressure. I'm considering making the FPR adjustable and lowering my pressure. That should cause the car to be less rich right? How much should I drop the pressure at first? Should the car maintain fuel pressure after you turn the car off? Thanks.
Bill
Old Apr 18, 2003 | 07:32 PM
steve8586iroc's Avatar
I would say that you have other issues than high fuel pressure. If the car is otherwise stock you might want to check your o2 sensor. Do you have any other data you could give us?
Steve
Old Apr 19, 2003 | 07:44 AM
Dan W's Avatar
How does your air cleaner look?
Old Apr 21, 2003 | 09:53 AM
SlowT's Avatar
Just a thought?
If your BLM's are low and the engine is rich,doesn't that mean that the computer is adding fuel,to make up for what's not there?
So if you physically add more fuel(just a little goes a long way)shouldn't that help?
Old Apr 23, 2003 | 11:58 AM
BillD91RS's Avatar
If the BLM's are low then the computer is removing fuel to compensate for a rich condition.
Old Apr 23, 2003 | 12:22 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Your blm's that low with stock heads, cam, and intake?
Old Apr 23, 2003 | 01:07 PM
SlowT's Avatar
That's right I got confused my bad
Old Apr 26, 2003 | 03:17 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Maybe, check the 02 sensor (get a new one only $18) and check for some exhaust leaks before the 02 sensor, that will make the computer think you're running lean. This car has a stock cam?
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
CORV3TT3
Aug 23, 2015 11:26 AM
tmellott89
Aug 16, 2015 02:58 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
