i have a bone stock 89 tbi i want power?
Old Apr 24, 2003 | 08:56 AM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
well my 89 camaro is very slow and tekes to long to get speed it is completly stock from the front to the back of the car.it has all that pollution pump b/s and the headers and crap.what easy mods can i do to make some more power and make it run like a 14.3 1/4 time?i dont have much money but give me a list of parts to buy they told me an edelbrock air cleaner 3 in tall by 14 in how much does that help?
Old Apr 24, 2003 | 09:03 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
First off, do a good tune-up.
second, how much money DO you have.
top TBI mods:
Open Element, Ultimate TBI.
Exuast, headers --> Cat-back.
Gears/posi.
Old Apr 24, 2003 | 09:16 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
money is not the problem for me but i want to get all the low cost parts that will give the most power and then i go with the expensives like heads and valve train complete.oh and by the way i do have a posi but i dont know what gears ?how do u know what gears a posi has?
Old Apr 24, 2003 | 09:32 AM
1989camarorsrs's Avatar
if its the stock rear, 2.73s wit auto and 3.08 with manual
Old Apr 24, 2003 | 10:38 AM
vjo90RS8's Avatar
Car: 2002 Z28
Open element w/K&N
Ultimate TBI mods
Headers, hi flow cat, 3" cat back
3.42 or 3.73 gears with SLP $99 take off posi
Old Apr 24, 2003 | 10:52 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
To get low 14's on all motor the shortest easiest way is to
Change the engine. $1800 shipped http://www.sdpc2000.com/cart.asp?act...id=128&pid=105
Change the injectors 55lb Injectors:AC/Delco part#17112493 $190 for a set.
Ultimate TBI mods: https://www.thirdgen.org/newdesign/t...imatetbi.shtml
95+ S10 4.3L torque converter part number 24202310. I paid $100 for mine.
350 Knock Sensor: #10456288 ,$25.22 at gmpartsdirect.com
350 ESC Module: # 16128261,$46.37 at gmpartsdirect.com
350 computer chip for $50.
Complete exhaust change from the engine back with parts for a single cat TPI car = $500
Providing that your car has been altered and has posi then you may not need to mess with it. But likely you will need to change to 3.42 or 3.73 gears and posi which will cost you around $700 installed.
You can get in the low 13's with a Vortec 350 but that is going to cost about $1000 more and more work to get running.
Old Apr 24, 2003 | 10:55 AM
vjo90RS8's Avatar
Car: 2002 Z28
yeah, ill be doing that swap after the tranny. L05, LT1 cam, Edelbrock TBI intake, either 48mm TBI or Holley 2", 65# injectors, cop car chip, and all my current mods. The engine is actually alittle cheaper at www.paceparts.com but only by like $7.
Old Apr 24, 2003 | 12:12 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i would do a full tuneup, and then look into a full exhaust system. HEY! kinda like what i got for sale in my sig
Old Apr 24, 2003 | 03:38 PM
rsboy350's Avatar
thanks alot but were else in miami can i find these thing i they in a junk yard?
Old Apr 24, 2003 | 06:11 PM
HIBERNIS's Avatar
Transam creations USA, sells everything you need, Its basically a junkyard for F bodies. Or try ebay, but be careful.
The website is ,www.tacreationsusa.com , their in hialeah.
In their website, they dont have any aftermarket parts posted, but Im sure if you go to their facility in person, you can find used aftermarket parts from other 3rd gens.
Old Apr 24, 2003 | 11:49 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Re: i have a bone stock 89 tbi i want power?
Nitrous is by far the easiest way to reach your goal, but otherwise doing it NA here's some options.
I think we should make a sticky on what are the basic mods everyone does to make a 305 TBI car run 14's.
TBI mods and 1/4 mile times
Old Apr 29, 2003 | 07:39 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
so i can run a 14.6 1/4 time i will need
1.cam
2.heads
3.open elemnt
4.chip
5.gears
6.headers
7.exhaust
8.smog pump removal
will i run that time with what i listed or worst or better?
Old Apr 29, 2003 | 07:55 AM
Dewey316's Avatar
Car: 1990 Camaro RS
who knows, there is alot more to getting an ET than just the engine mods, it comes down to the driver, the suspension, the engine, the tranny, it is a whole package. i would bet that my car would beat an equaly moded car with stock suspension pretty soundly in the 1/4, i can cut a sub 2sec 60' with my basicly stock lo3 and t5.
Old Apr 29, 2003 | 10:38 AM
Engine: LS7
1.cam
2.heads
3.open elemnt
4.chip
5.gears
6.headers
7.exhaust
8.smog pump removal
You should be able to run mid to low 14s with those mods, but tuning is extremely important as well as traction. I turned my 14.4 time into a 16.4 by having some ignition related problems(plug wires). So tuning is very important. Most parts you can just slap on there, but cam and/or heads require custom chip tuning to get the most power from them.
Old Apr 29, 2003 | 01:14 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
were in miami florida can i get a custom chip?
Old Apr 29, 2003 | 04:32 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
if you want to figure out what gears you have, put the rear of the car on jackstands so neither rear wheel is touching the ground.
put the transmission in neutral
put a mark on one of the tires.
crawl under the car and put a mark on the driveshaft
while you stay under the car, have a buddy turn the marked wheel exactly one full revolution.
watching the mark on the driveshaf, count the number of revolutions. if the driveshaft turns 2 3/4 times, you have 2,73s. if it turns 3 3/4 times, you have 3.73s. if it turns a little over 4 times, you have 4.11s. if it turns 27 times, you have big trouble.
BRoss99
Aug 10, 2025 05:08 PM
jaridjohn
Jul 8, 2024 03:49 PM
MustangBeater20
Oct 29, 2022 09:20 PM
InfinityShade
Aug 22, 2015 08:00 PM
sreZ28
Aug 14, 2015 07:48 PM
