A couple of questions about my LO3 buildup/
Old May 15, 2003 | 09:04 PM
raggedout91RS's Avatar
Car: '84 Z28
Engine: Goodwrench 350
Axle/Gears: good guess
Hey guys I've got two questions that I need an answer to. First, for all of you that have switched to 416's, what did you do to make your temp. send. unit and fan switch work w/ the 416 heads. The threaded holes in the heads are bigger than the ones in my TBI heads. Second, can I run a standard double row timing chain on my roller LO3?
Old May 15, 2003 | 09:26 PM
iroc22's Avatar
Go to any parts store and get a brass adaptor fitting. I can't remember the size off hand.
Old May 15, 2003 | 10:44 PM
25THRSS's Avatar
Couldn't you get a sending unit off of a car that came with 416 heads?
Old May 16, 2003 | 06:03 AM
Car: '84 Z28
Thanx for the comments....how about the timing chain?
Old May 16, 2003 | 06:47 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the heads shouldn't effect which timing chain you use.
make sure to get one for a factory roller block setup.
(hint: summit brand (i think it is a comp or cloyes chain) sells one for 40 bucks, it is double roller.
Old May 16, 2003 | 05:42 PM
Car: '84 Z28
I knew the heads would'nt affect my timing chain . I meant to say that I've heard from somewhere that you cant use a oldstyle timing chain (pre-roller) on a roller motor...I'm not sure if this is true so that is what I was asking. I've alredy got a double roller and was'nt sure.
Old May 16, 2003 | 06:54 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I put a new double roller in mine about 6 months ago - no problems. I just picked it up at CarQuest - about $54 with gaskets.
I never thought about have different sized holes for switches in the 416's - ooops - LOL - I just got my 416's back from machine shop yesterday.
Old May 16, 2003 | 07:40 PM
Car: '84 Z28
I bought this double row timing set from Summit. I think it was like $15. I dont think its a double roller just a double row. Any ideas?
Old May 16, 2003 | 07:42 PM
Car: '84 Z28
Nevermind guys, I just looked back in Summit and it says...."not for factory roller cams".
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
