Timing ??????
Old May 18, 2003 | 11:22 AM
chevysteve's Avatar
Timing ??????
I have a 90 350 TBI....when I set checked the timing....I noticed that the timing mark would stay at 0, then would suddenly jump to 20 degrees when reving engine. Back to idle, O degrees again...just jumps from 0 to 20 , no smooth movement at revup. Is this normal?????? Also, the reason I checked it to begin with, I have a bad knocking. I did replace the knock sensor, but didnt help. I tried 94 octane. Made very little difference. I tried a new computer. No better. Added new MAP, no better either....HELP!
Old May 18, 2003 | 05:06 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
Make sure that you have the Electronic Spark Timing module unplgged when you are checking the timing. I'd check the distributor components to make sure that they aren't worn out. Not just the cap and rotor but the module and the distributor mechanisms as well.
Old May 18, 2003 | 08:01 PM
steve8586iroc's Avatar
Can you explain the knock in a little more detail?
Steve
Old May 18, 2003 | 08:19 PM
chevysteve's Avatar
Sounds ok at idle and sounds good reving engine. It only happens under a load. Driving down road and accel. fast, etc.
Sounds like valvetrain noise.
Old May 18, 2003 | 09:33 PM
Check your egr system. If it doesn't work properly it can't cause a bad knock problem.
Steve
Old May 19, 2003 | 05:35 AM
chevysteve's Avatar
Yep......I also installled new EGR.
Old May 20, 2003 | 04:51 PM
Did you check to make sure the passages weren't blocked?
Steve
Old May 21, 2003 | 05:39 AM
chevysteve's Avatar
Everything looks ok, I just tore the engine down, valvetrain looks ok, going to pull the crank and rods today. 130,000 miles and the cylinders look good with very little ridge. I kinda hope I find a problem with the bottom end so at least I will know the problem.
Old May 22, 2003 | 05:03 PM
chevysteve's Avatar
dropped off the engine at my machinist today.....looks as though I had a piston slapping a little....so Im going .030 over with a new rv cam......hope she runs good.......thanks for your input!
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
