TBI Cam
Old May 23, 2003 | 09:18 AM
highpower's Avatar
TBI Cam
Anyone have any ideas on what type of cam I should use to upgrade my 305 T.B.I. Elelbrock said they didn't have one for the EFI motor and to try Comp Cams pt#08500-8, does this sound right? Any sugestions?
Old May 23, 2003 | 09:26 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Specifications:
* Advertised duration: 258 intake/264 exhaust
* Duration at .050 in. cam lift: 206 intake/212 exhaust
* Gross valve lift: .480 in. intake/.488 in. exhaust
* Lobe separation: 112 degrees
* RPM range: 1,000 to 5,000
* For use with stock throttle body
* Very good economy and power
Those are the specs for the comp cams you listed.
tell us more about your car first though, what mods do you have done if any, what rear-end ration, what tranny, ect.
Old May 23, 2003 | 09:37 AM
highpower's Avatar
I am fairly new to the F-bodies but loving them(I crossed over from sport compact cars) In the 3 months that I've had the car I've added a Flowmaster 80 series cat-back, Edelbrock intake, 180 stat, MSD plug wires and Splitfire plugs. No rear end mods, yet, what to get posi and short throw shifter. So what type of cam are those specs for? and will I need to upgrade/change the heads, lifters, springs, etc??
Old May 23, 2003 | 09:44 AM
Dewey316's Avatar
Car: 1990 Camaro RS
those specs are for the part# you had in your post.
heads you don't have to , but the ones on the TBI are junk, if you are willing to spend a few hundred and do heads, you will be very happy.
lifter, no, hydrolic rollers do not need to be replaced like on flat tappets.
springs , i would change these for sure.
but if you change heads, do note that the cam you want will probably change.
best recomandation i have, is to call comp cams, and let them pick you a cam.
Old May 23, 2003 | 08:10 PM
chevy8ford's Avatar
Car: 88 Firebird
Welcome back to the light side, anyway, i would also toss the spitfires, and just stick with normal old delcos (A/C Delco)
Mike
Old May 26, 2003 | 12:48 AM
pat12spe's Avatar
I'm not sure about sticking with the AC delcos. I just put in some bosch platinum +4's with 8mm wires and I'm very very pleased with them. Somethin to definitely check out.
Old May 26, 2003 | 01:17 AM
chevy8ford's Avatar
Car: 88 Firebird
If anything it was the new plugs that made the difference, but if you feel ok spening like 4.00 a sparkplug, by all means, feel free...
Old Jun 5, 2003 | 04:44 PM
deadhead1882's Avatar
Car: 82 El Camino
Engine: built 355
Transmission: T-56 upgraded internal
Axle/Gears: 10 bolt 3.42
i had the platnium 4s in my 92 and didnt like them they burn to hot, back to good ol ac delco's and can get 8 for the price of 3 platnium 4s
Old Jun 5, 2003 | 07:28 PM
James Montigny's Avatar
I've always had the best luck with ACDelco standard plugs. Rapidfires worked nice as well, but no justification for $4/plug
As for the 2 or 4 tipped jobs, I think they are about as useful as the stickers they come with.
Old Jun 5, 2003 | 08:55 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I would save up and do heads/cam at the same time.
Old Jun 9, 2003 | 07:42 PM
highpower's Avatar
Well, I went ahead and got the LT1 cam and springs gonna wait an see if I can get a deal on some roller rockers before I tear into the motor figure I should do it while I'm in there. As for the plugs, I've trid the delco's and they work great but, I do see an improvment with the 3 extra leads.
:rockon:
MustangBeater20
Oct 29, 2022 09:20 PM
junkcltr
Aug 2, 2019 11:12 PM
509 camaro fan
Sep 6, 2015 10:43 AM
z28addict8490
Sep 5, 2015 03:56 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
