TPI heads really worth it?
Old May 23, 2003 | 02:14 PM
firebirdconv92's Avatar
Car: 2001 Silverado (I miss my 3rd gens)
Engine: 4.8
hey, i have the opportunity to get some heads off a 1991 305 TPI for pretty cheap. The guy said that I could take them to a shop and if they are cracked he will give me my money back. I was just wondering if it would be worth all the effort of tearing my motor apart to put these on? What kind of gains should I expect?
Old May 23, 2003 | 10:57 PM
Keith5's Avatar
Car: C1500
I put them on my car, and I think if I were to do it over again I would leave the heads out. Save the time, money and effort for a rebuild or a bigger displacement engine. If you were rebuilding the engine it might be worth it, but if you're putting them on an engine with some miles on it I would skip them.
For what you would spend for a valve job you could probably do the lt1 cam swap and get new vavle springs.
P.S. if you do get the heads, and if you are already going to get a valve job done on them, have 1.94 intake valves put in them, I wish i would have done that.
Old May 25, 2003 | 01:51 AM
ZRATED's Avatar
the heads will be worth it if you get them for a really cheap price an port, polish them, and get bigger valves on them, but keep in mind not to spend to much, cuase vortec heads willl be much better in the long run
Old May 25, 2003 | 02:10 AM
samdog1232000's Avatar
Car: 92 RS 25th Anniversary
Engine: 350 L98 w/Vortec Heads
Transmission: 700 R4
True, Vortec head will be better but then you would have to buy the Scoggins intake which is about $400.00. But if you are willing to do that it is no biggie!
Old May 25, 2003 | 02:16 AM
25THRSS's Avatar
No you wont. Edelbrock makes a vortech carb intake that can be used with a tbi adaptor plate. GM even makes a vortech tbi intake manifold.
Old May 25, 2003 | 02:26 AM
Your right, the scoggins is for the TPI setup, price wise though it is the same! I dont know about the Edelbrock setup though?
Old May 25, 2003 | 02:27 AM
25THRSS's Avatar
You can use any carb intake manifold for tbi as long as you have an adaptor plate.
Old May 25, 2003 | 06:34 AM
Keith5's Avatar
Car: C1500
The vortec TBI intake is $350 from jegs. Carb intakes are a lot cheaper.
Old May 25, 2003 | 10:32 PM
Oh I never priced stuff on Jegs, the intake I was looking at was in the GM performance catalog, I usually try to buy parts factory because I get it at cost!
Old May 25, 2003 | 10:48 PM
Engine: 4.8
yeah, I found a better deal with a guy I met on these boards and he will sell them to me for 40 bucks.
Old May 26, 2003 | 06:55 PM
What are the specs on TPI heads, for ex the ones on a 92Z
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
