370 horses?????
Old May 29, 2003 | 05:59 PM
jbird91's Avatar
370 horses?????
hey i went to ebay motors and typed tbi engine and found a 370 horse engine. has anybody seen a tbi engine make this much power. im thinking of asking the seller to show a dyno sheet to prove it... would be nice if it were true...
Old May 29, 2003 | 07:47 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
Old May 29, 2003 | 10:27 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
to make that power, you need big cam, good heads, high rise intake, 2" tbi w/ big injectors. All this still won't make 370 hp with out major tunning.
Old May 29, 2003 | 10:36 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
is it a big block or small block?
i bet the TBI 454 is capable of 370 with some work
Old May 29, 2003 | 11:26 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I think a "super done" 350 with 454 throttle body could put out 430hp. Say if it had AFR 210 heads, circle track cam, single plane intake.
Old May 30, 2003 | 12:19 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Ask for a dyno sheet, timeslips, something.
Old May 30, 2003 | 01:01 AM
ZRATED's Avatar
I found some engines like that too, they are mostly BS
The engines are proly built with stock heads and are 370 HP on paper with no testing on the dyno or the track
Old May 30, 2003 | 01:41 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I really doubt a 2bbl tbi is gonna be able to put out those numbers. My 383 is BUILT (good for 400+hp), but even after my fuel pump and chip tuning I only expect 105mph in the quarter with the holley 670 and 85pph injectors. Maybe 360hp at the flywheel. A 4bbl tbi on the other hand could handle 370hp without a problem.....
Old May 30, 2003 | 01:13 PM
iroc22's Avatar
What's the displacement of the engine??
Old May 30, 2003 | 02:50 PM
HIBERNIS's Avatar
Have you ever heard of 402 hp and 344 lb-ft out of a 305? Im guessing some of you have stumbled upon this article by hotrod magazine.IT makes this hp at a pretty high 7200 rpm, the torque peaks at 5500 rpm. They used a 2 barrel 650cfm carb during the dyno sessions. Check it out if you havent yet.
290HP http://www.goingfaster.com/spo/290hp305.html[/URL]
325HP
http://www.goingfaster.com/spo/carcraft325hp305.html][/URL]
402HP
http://www.hioutput.com/tech/400hp/400hp.html][/URL]
Old May 30, 2003 | 04:44 PM
JR305's Avatar
Here is an auction for one of those 375hp TBI engines.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2416956019
It is a 350 with a ZZ4 cam, Vortec heads, and a GM TBI vortec manifold. Looks like the engine could make the 375hp, ZZ4 engines make 355hp. Vortec heads should be about a 20hp increase over the ZZ4 (L98) heads. But if the guy does have dyno numbers I bet they are with a carb. I agree with r90camarors, I don't think a 2bbl TBI can support that much power.
Old May 30, 2003 | 05:08 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
They used a 650 cfm dbl. pumper. That's a 4 barrel carb.
And 650 cfm @ 1.5"/Hg is plenty enough for a 305 to make that kinda HP at that RPM. But make it tolerable on the street? That's another story.
Old May 31, 2003 | 07:39 PM
jbird91's Avatar
What is the most power that has been proven out of a tbi system. i need to decide wether or not to convert to tpi or an aftermarket injection. Anybody got some good dyno #s thanks for the info
Old Jun 1, 2003 | 02:14 PM
Engine: LO3;383tpi
Are you talking 2bbl or 4bbl? A 4bbl will be able to handle up to 600hp as rated by holley. I'm guessing it is more than that, as holley only rates their 670 cfm unit at 275hp, but it has proven good to 320hp so far.
Old Jun 1, 2003 | 08:21 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
No dyno for me, but the "cheazzy" online hp calculators say that my trucks weight with the time I run, works out to about 400hp. I'm aware that those calulators are just a vag guess.
italiano67
Dec 11, 2016 09:21 AM
scottmoyer
Sep 5, 2015 09:33 AM
z28guy134
Sep 1, 2015 11:50 PM
Chevy3shitty
Sep 1, 2015 02:10 AM
Brandog87GTA
Carburetors
Nov 15, 2000 12:28 PM
