E/T times
Old Jun 6, 2003 | 10:08 AM
92 305 BIRD's Avatar
Car: 1992 Firebird
Engine: 305 TBI (LO3)
Transmission: TH-700R4 w/Shift kit
E/T times
what are everyones e/t times in the 1/4. if someone had a auto with 2.73 that would help im just wondering what kinda times my car would get
Old Jun 6, 2003 | 10:17 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
well i have hte same mods as you
but a 5-speed and 3.08s
i ran 16.1 @ 89MPH (yeah you read that right)
so if you can get traction, you whould be upper 15's
Old Jun 6, 2003 | 08:48 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Check the link in my signature for the TBI time registry, that should give you some idea as to what TBI can do with what.
Old Jun 6, 2003 | 09:04 PM
25THRSS's Avatar
"Sorry, the page you requested was not found"
Old Jun 7, 2003 | 01:15 AM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
My car with just the flowmaster and k&n ran a 15.7 but it also ran a 15.9 stock so go figure.
Old Jun 7, 2003 | 11:50 AM
maroon91rs's Avatar
Car: 91 Camaro RS
Engine: L03 305 baby!!!
Transmission: stock 700r4
in the sig
Old Jun 7, 2003 | 12:00 PM
SC2camaro's Avatar
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
hey dude
hey
the last time out i ran a 10.51 @ 67 mph with a 2.32 60 ft thats a 1/8 mile
car is basically stock except for free mods auto with 2.73 gears.
k/n air cleaner mods gutted cat soon to get a cat- back exhaust and a chip burnt
Old Jun 10, 2003 | 02:06 PM
S!MON's Avatar
Car: '87 Camaro Z28
Engine: fully loaded 350
Transmission: T5-World Class
tbi, 5-speed, 3.08, no ac, no power windows, no power lock, no power at all *lol*
mods:
accel 300+ wires
aluminium driveshaft
10x2 open element
filled it up with 100octane gas (shell v-power)
I ran a 16.1@82.87
I woul say it's a good time for a nearly stock lo3 with heavy steel rims!
greetz
S!MON
Old Jun 10, 2003 | 02:16 PM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
It was bogging down on launch, so there is more in the car.
14.851 @ 94.83
60' = 2.6
Old Jun 11, 2003 | 12:46 AM
FreeLoader's Avatar
Car: 1997 Camaro z28
Engine: 350 LT1 built to LT4
Transmission: a
Axle/Gears: 3.23 posi
my totally stock lo3 with 2.73 and an auto ran 18.4, though there's a LOT of reasons to doubt it, some of them being I was running on low air un-even bald tires, with a ton of extra weight in the car(stuff not people), and it was my first time out there. And thats just SOME of it, so i really wouldn't go by my time, i intend to go back out there and clear my name!
Old Jun 11, 2003 | 02:39 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
see sig for time.
Mods:
Hooker 3" cat-back
Cat delete
Open Element
Accel 8.8mm wires
Accel Cap/Rotor
+2* timing
Tires:
215/65/15 Potenza RE92's
(rears @ 24lbs)
the 15.8 ET was on a 2.456 60ft(at a bad traction track).
Car has the pegleg 2.73 non-posi rear-end. Car is definately capable of a 2.2 60ft. Guarantee when I run at a better track and advance timing to ~8* it'll come down and the car will be mid 15's.
Motor has 207,000kms
Old Jun 11, 2003 | 03:00 PM
1bad89bird's Avatar
hey can you guys tell me what do you think my car will do at the track? never gone out there. look at my sig for details on car those are only mods.
Old Jun 11, 2003 | 03:03 PM
1bad89bird's Avatar
sorry guys here is the sig
Old Jun 11, 2003 | 03:05 PM
25THRSS's Avatar
I say low 15's
1bad89bird's Avatar
i also have air shocks in the back ive raised them for better traction and ground clearence for the mufflers
Old Jun 11, 2003 | 03:07 PM
25THRSS's Avatar
raising them will hurt traction.
Old Jun 11, 2003 | 04:05 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
It's in the sig. My 60' was 2.230 which I think is a little slow but I did a shallow stage so it could be helped maybe.
Old Jun 11, 2003 | 09:43 PM
novadk13's Avatar
Car: 92 Firebird,74 Nova
Engine: Stock tbi,Vortec 350
Transmission: T56, th350
Axle/Gears: 3.73 LSD, 2.73 open
on the g-tech i ran a 15.8 before any mods and less than a 1/4 tread left which was also dry rotted. i havent tried it yet on my new tires and with my headers with full cat back.
Old Jun 12, 2003 | 12:43 AM
FreeLoader's Avatar
Transmission: a
oh hey s!mon, i didn't see this until just now, but you should try going out to the track on a lower octane, try 91 or 89 or even 87, ill bet you you'll run better times.
100 octane is overkill unless you have a high, high compression cast-iron headed engine with a high degree advance.
Old Jun 12, 2003 | 04:25 PM
S!MON's Avatar
Car: '87 Camaro Z28
hmmm. I felt the differnce (positive) after I filled my tank with this stuff! but I won't do it anymore: 1.23€/liter! that's definatley too much for me! now I fill in 95 or 98octane gas, because I will set the timing a little bit higher.
but thx and greetz
S!MON
Old Jun 13, 2003 | 06:27 PM
Car: 1992 Firebird
well now i have 3.42's what times should i get with thoses
Old Jun 13, 2003 | 10:18 PM
RSCamaroGuy92's Avatar
Car: 92 Camaro RS
Engine: 355 94 p/u motor
Transmission: 700R4 With TCI kit
In a perfect setup, 89mph on a camaro should get you 15.7's if you get a good 60'
Old Jun 13, 2003 | 10:21 PM
Car: 92 Camaro RS
Re: hey dude
Originally posted by SC2camaro
hey
Anyone else see something wrong with this!!!!!??????!!!!!!
Time is WAYYY OFFF MPH IS WAYYYY OFF. but at least the 60' seems reasonable. LOL
Either bad type-o or this guy is
Old Jun 13, 2003 | 11:41 PM
25THRSS's Avatar
He's talking about 1/8th mile.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
