Removing A.I.R. System
I was wondering if it would hurt to just route the belt to remove the smog pump....
BUT leave the actual smog pump on the car, just simply by-pass it on the serpentine system...
Will this cause any harm??
it would be "fine" to do as it would not hurt the engine, but there are two reasons for doing that mod and you would only be getting the effect of one: 1.) to keep the recirculated air out of the engine (that you would have) and 2.) to regain the 5-10% of horsepower lost by having the motor run the smog pump (that you obviously wouldn't gain)
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
"1.) to keep the recirculated air out of the engine (that you would have) and"
Huhh? Please explain this.
S-D
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
In my opinion, the only reason to remove the smog pump is simply for a cleaner engine bay. You will not feel or see any improvement in performance. I think the pump only runs whike your car is warming up anyways. Weight savings of are very minimal as well, maybe 10-15lbs tops, I can't remember. It is nice not having those darn hoses though.
Well i'm doing it because
1. To save the weight from the front of the car....
2. To reduce the amount of junk in there....
3. I don't have Emissions in my state.....:lala: :lala: :lala:
Engine: LO3;383tpi
Sounds good. It will definetely get rid of a lot of the junk in the engine bay. Your first step to making your engine look as sweet as the rest of your car
Car: 92 Camaro RS
so can we see pictures of routing the belt without the AC or AIR, w/out using delete pulleys...
Car: 92 Camaro RS
Engine: 355 94 p/u motor
Transmission: 700R4 With TCI kit
Maybe I can save you $$ and time
I see you live in florida, so listen to this. If you plan on driving your camaro on the street, you better not get rid of the smog stuff. I live in Central Pennsylvania and my state just adopted a federal regulation mandating visual inspections of factory pollution control devices and tampering of them. So, I had to buy new headers, smog pump, the lines, a cat, and a few other hardware pieces. It was very expensive, like almost a grand for me to get all these things, just so I could pass a normal state inspection.
It is my understanding that the federal government has mandated that these inspections start over the next few years in all state, so save yourself the hassle and time and leave that stuff be.
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
he has an LS1 under the hood, if that doesnt look good to you, what does?
Car: 92 Camaro RS
Originally posted by BronYrAur
You guys have to check dates on these posts. That reply was made over a year ago!
RScamaroguy
Anything i take off my car, i keep jsut incase i need to put it back on eventually. So I intend to remove the A/C and the A.I.R. Pump for now, and jsut stash them away soemwhere along with my other stuff... any diagrams/belt routing on how to do this tho?
i have an idea, ill post a pic and you guys can tell me if it will work?
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
this may help. not the best pic, but you can sort of see the routing.
Car: 92 Camaro RS
Dewey, What kind of hood do you use with that open element e-brock? Just wondering, b/c it would seem to me that as hot as these motors get, (especially the headers) the air you would get without a cowl, shaker, or ram-air hood would be so hot that it wouldn't be much better than the stock snorkle with cooler air in it. Just wondering b/c I used to use an open element too, and I have seen .43-.50 second gains and 3-4mph goin to cai from an open element.
Car: 92 Camaro RS
Heres the routing i thought up the other day in school. any reasons it wouldnt work? or i might run into problems?
i realize i MIGHT have to reverse the belt tensioner... but other than that i think it will be the simplest belt re-routing...
Car: 1990 Camaro RS
RS,
I have the stock hood. BUT i have very carefully and cleaverly directed cold air towards the intake, and opened up paths for hot air extractions
Adrenaline-- That would work. I have seen a couple of people do it. You do have to take apart the tensioner and reverse it.
backtothe80s
Sep 5, 2015 12:39 AM
Street Lethal
Aug 13, 2015 08:28 PM
