Sticking throttle body
Old Aug 15, 2003 | 10:52 AM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Anybody have problems with their throttle sticking on the TB? I've squirted WD-40 on the linkage but it still seems to stick, especially in the early morning when i go to work. Has anyone tackled this issue yet?
Old Aug 15, 2003 | 12:49 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
if the throttle sticks when you first try to press on the gas then thats usually a sign of excessive wear around the throttle shaft. You can get it rebushed if you want to since you said its a modified base from turbocity in another thread.
Old Aug 15, 2003 | 01:09 PM
pwdbychevy's Avatar
Is it difficult to have that done? Is that something I can tackle myself? Thanks.
Old Aug 15, 2003 | 04:41 PM
Car: 88 Camaro SC
Engine: SFI'd 350
youd have to ahve a machine shop do it unless you know how to do some basic machining and have access to the proper equipment.
Old Aug 15, 2003 | 05:43 PM
pwdbychevy's Avatar
Thanks for the info.
Old Aug 17, 2003 | 05:39 AM
RS91's Avatar
I had this problem before.... I removed the metal that cover the screw (idle screw) to adjust the throttle blades. You will need a torx to turn it until it no longer stiks...
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
