Timing advance question?
Old Sep 7, 2003 | 10:43 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I am going to try to advance me timing in a couple days. But before i do it, i wanted to find out if there are any disadvantages to it. Will it make it idle differently? What kind of drawbacks are there? Also any helpful advice will be appreciated.
Old Sep 7, 2003 | 07:13 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
You should run Winaldl if you can to check your knock counts. Advance it like 2* at a time and keep checking it. I advanced mine 6* right off the bat and it pulled harder and idled smoother but I was getting an insane amount of knocks on winaldl (none that were audible) on 89 octane. Other than that there really aren't any downsides to advancing it a little. At 4* right now it idles smooth, pulls hard, and I think your gas mileage should increase as well.
Old Sep 7, 2003 | 08:35 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Ok, thanks for your help. I will let you know how it goes after i do it.
Old Sep 9, 2003 | 03:45 PM
nick harmon's Avatar
Car: 91 RS
Engine: LO3
mines at 6 BTDC with no audible knocks but i cant afford the comp. software nor hardwear to do any farther testing, but there is definitly a SOTP diff.! of course i have to run 93 octane.PITA $1.82 a gallon!
Old Sep 11, 2003 | 10:32 PM
92 z28's Avatar
dont complain, its $2.10 in ny now
Old Sep 11, 2003 | 10:36 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
I upped mine to 6* advanced, it idles slightly higher, only drawback is rising gas prices. Oh well.
Kevin
Old Sep 12, 2003 | 01:29 AM
vjo90RS8's Avatar
Car: 2002 Z28
i had mine at 6* but just bumped it to 8 because i added some 1.6 rocker arms and i run 91 octane.
I have you guys all beat with gas prices, Bay Area, CA.......enough said
Old Sep 12, 2003 | 01:31 AM
25THRSS's Avatar
notice any SOTP improvement with the 1.6's?
pfsteichen
Feb 9, 2016 06:59 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
