what roller rockers to get
Old Nov 7, 2003 | 11:54 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey i want 1.6 roller rockers for my 89 camaro tbi ?i know i need self aliging correct?and which are the ones that fit my stock vales covers center bolt?
Old Nov 8, 2003 | 04:34 AM
chevypower's Avatar
Car: '89 Formula, '97 Z28, '88 Formula 350
Engine: 305 TBI(LO3)
Transmission: TH700R4(MD8)
I think you will have to cut the baffles out to run 1.6 RR's.
Old Nov 8, 2003 | 08:25 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
baffles ?what is that?i seen companys that say fit center bolt vavle covers but i cant remember which company are they
Old Nov 8, 2003 | 11:09 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Baffles are the verticle supports in your valve cover. if you took one off and flipped one over you would see what I mean. You can cut them out and still not have any oil leaks or problems with the valve covers. Or you could buy new ones that have clearance for larger rockers.
Old Nov 8, 2003 | 12:33 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i beleive crane makes some that are narrowed boddied and fit. call summit and talk to one of their people, they can point you in the right direction. if it was me, i woudl run the comp pro-mag RR's, they are THE choice for a RR for a street car.
Old Nov 8, 2003 | 01:53 PM
joshwilson3's Avatar
Old Nov 8, 2003 | 02:46 PM
Dewey316's Avatar
Car: 1990 Camaro RS
IMHO its not worth it on a basicly stock L03, there are alot better places to toss $250.
Old Nov 8, 2003 | 04:15 PM
vjo90RS8's Avatar
Car: 2002 Z28
I gained over 2 tenths and over 1 MPH from installing some Federal Mogul Stamped Steel 1.6 rocker arms, only $68 from www.sdpc2000.com
Old Nov 8, 2003 | 05:52 PM
25THRSS's Avatar
I was under the impression that the comp pro magnum roller rockers would fit under the stock valve covers with the baffles intact? Anybody know for sure?
Old Nov 8, 2003 | 08:43 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
Dewey where'd you find SA pro mags for $250? or was it just a figure you threw out there... got me interested either way.
Old Nov 8, 2003 | 11:13 PM
Dewey316's Avatar
Car: 1990 Camaro RS
i would have to look, i run guideplates, so when i priced them they were like $256 from summit. not sure if the SA ones are the same price or not.
Old Nov 9, 2003 | 01:21 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
they're not, they're like $324, how much were guideplate? (pt#?) and are they difficult to intsall?
just looking to save some of my not so plentiful money.
Old Nov 9, 2003 | 03:06 PM
Dewey316's Avatar
Car: 1990 Camaro RS
well, you would have to buy guideplates and pushrods and screw in studs, so you are over $100 to switch over.
Old Nov 9, 2003 | 06:28 PM
25THRSS's Avatar
check out thunder racing. They're a lot cheaper than summit or jegs.
Old Nov 9, 2003 | 08:43 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
wow thunder racing is much cheaper, the promags were like $287 there vs. $324 at summit.
The thunder racing site claims you can run the 1.6 promags with the stock valve covers.
If i were to switch to 1.6 rr's would there be anyother parts that i would have to replace? springs, valves, etc.? any i should replace? specify difference in 'have to' and 'should' please.
-chuck
Old Nov 10, 2003 | 06:30 AM
Dewey316's Avatar
Car: 1990 Camaro RS
springs are a maybe, i am not sure how much lift the stockers take. replacing springs is a good idea though. with howevermany 100k miles our cars have, they are going to be worn out. that is really the only thing you would need to think about replacing.
Old Nov 10, 2003 | 09:38 PM
25THRSS's Avatar
I've wanted to know the stock spring rates for a while now, but I dont think it would matter anyways. The stock cam is so dinky that even with 1.6's you would barely be over .4 lift and still way under that on the intake side. I doubt you would have problems, going from what others have experienced with 1.6 rockers on your cars.
Old Nov 11, 2003 | 08:27 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
I ran the comp magnum 1.6's with stock cam and stock valve springs and had good results. I had 150k miles on those stock springs. It pulled a couple hundred rpm's higher than it did without them. Then I went and changed the cam to a '95 lt1, which gave me .480 lift so i had to do the springs. I'll check out thunder racing next time I need parts- wish I knew about them before.
Old Nov 11, 2003 | 09:07 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i was told you cant run thoes rockers with the stock covers untouched unless you either ran a thicker valve cover gasket or ran 2 gaskets....
can anyone confirm that for me?
Old Nov 12, 2003 | 10:23 AM
the comp 1.6 magnums I used with the stock valve covers. They clear fine. But I am talking about the "roller tip" rockers. You may be talking about the "roller fulcrum" ones, designed like aluminum ones? If you are, I don't have experience with them but I understood it to be common knowledge that you'd have to use the "tall" valve covers with that type.
Old Nov 12, 2003 | 10:37 AM
Dewey316's Avatar
Car: 1990 Camaro RS
yes we are talking about the full rollers. i beleive i have read that they fit, you may have to do some hammering on the valve covers for clearance, but i have not tried it.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
