Good Heads
Old Nov 11, 2003 | 02:11 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
Good Heads
I have an L03 and I know they have horriable heads. If I could get a set of heads from a TPI car for cheap would that be a good idea. I need to change my valve springs and seals so I thought that if I had to open it up why not put new heads on as well. Anyone have a suggestion?
Old Nov 11, 2003 | 02:13 PM
iroc22's Avatar
Sure grab some TPI heads. Clean them up, maybe fix the rough castings and such, replace the valve seals and springs. They will flow much better than the 187s currently on the L03.
Old Nov 11, 2003 | 02:15 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
Any idea on hp #'s?
Old Nov 11, 2003 | 02:20 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
with the poor cam in the Lo3's i wouldn't expect too much from just swapping heads. with all the other issues on the lo3, if you are doing heads, you will have everything apart, you might pick up a cam for it....
PS, i am selling an UltraDyne Racing cam that would fit that bill perfectly
Old Nov 11, 2003 | 07:31 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
Well if I am doing all that I might as well pop in a new engine. Right???
Old Nov 11, 2003 | 10:02 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
ummm, No. Not necessarily. Heads and cam are critical components but far short of an entire motor cost wise.
What are you hoping to achieve with your car? Dewey (above) is running about 1 full second faster in the 1/4 than you with just tuning.
-Schultzy
Old Nov 14, 2003 | 11:49 AM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
I was just hoping to get into the 14's.
Old Nov 14, 2003 | 12:59 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
Would these be good heads???
http://cgi.ebay.com/ebaymotors/ws/eB...category=33617
And this cam???
http://cgi.ebay.com/ebaymotors/ws/eB...category=33614
Old Nov 14, 2003 | 01:01 PM
iroc22's Avatar
Yup those are 416 castings so they are the better 305 factory head.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
