car overheats after header install
Old Nov 25, 2003 | 12:44 AM
gunz4life2's Avatar
Car: '91 Firebird
Engine: 305 TBI
I installed a set of Summit headers a few weeks ago. Since the day I installed them, the car has been overheating badly. My radiator exploded after letting the car run in the driveway for 30minutes. I then installed an all metal radiator and it blasted a hole in the upper part of the tank. The timing has been set and checked several times, I changed the coolant, and the thermostat and hoses are in good condition. What could be causing the overheating? I can't run it for more than a 15minutes without it getting extremely hot.
Old Nov 25, 2003 | 01:28 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
2 options..
the simple, you messed up the fan relay on the back of the passenger side head during the header install.. disconnected the wire and didn't reconnect it, physically damaged it through rough handling of the header, etc.. (is your cooling fan coming on?)
the extreme, she's leaning out beyond the capability of the cooling system to take care of. seen your headers glowing lately?
Also, pressure buildup should not be so extreme as to blast holes in an all-metal radiator.. your radiator cap and overflow system probably need some TLC..
Old Nov 26, 2003 | 12:15 PM
jpk91rs's Avatar
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
I second that opinion.
Old Nov 26, 2003 | 12:22 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
I third that or you messed up the spark plug wires and where they go.
Kat
Old Nov 26, 2003 | 09:27 PM
gunz4life2's Avatar
Car: '91 Firebird
Engine: 305 TBI
I think maybe it's leaning out. The mechanic that put on the headers also gave me a TBI unit from a V6 Caddy....which would mean a lower FP setting and possibly weaker injectors...right? The fan comes on and all the Spark plug wires are in the right place.
Old Nov 27, 2003 | 10:36 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
:wtf:
Put the 305 injectors back on there.. The V6 ones flow considerably less.. Also kick the mechanic in the nuts and go find a different one.
Kat
Old Nov 27, 2003 | 02:20 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Old Nov 27, 2003 | 05:19 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I have been having the same problems after i installed my hedders too, except for not as bad. I have to run my fan almost all the time.
Old Nov 28, 2003 | 10:04 PM
WhyHelloOfficer's Avatar
Car: 1994 Camaro Z-28
Transmission: A4
Are your headers coated at all?
And someone please tell me why your mechanic did that?
-Joe Bliz
Old Nov 29, 2003 | 02:33 AM
gunz4life2's Avatar
Car: '91 Firebird
Engine: 305 TBI
The mechanic is some "poor-town backroad" mechanic. He isn't used to working on Fuel injected cars (obviously). I didn't know much about these cars either, that's why I took it to him. He said he could fix it for me and I just wanted my car to run. When I picked it up the next day, it ran. I had already made the AFPR and added an injector spacer (he trew it all away because he said I damaged it) They've never heard of the internet down here, so they've never seen any of the tech articles on that stuff. I'm going to try to do most of my work myself from now on with the help of DIY articles and books. Thanks for the help guys.
1992 Trans Am
May 10, 2023 07:19 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
bryan623
Aug 10, 2015 11:33 AM
mustangman65_79
Aug 7, 2015 09:55 PM
drathaar907
Aug 6, 2015 04:20 PM
