Need Opinions
Old Nov 26, 2003 | 07:44 AM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
Need Opinions
Ok Guys Im gonna be doing headers on my 89 formula Lo3 as soon as the headers come in from Jet-Hot. I plan on changing the plugs and doing a full tune up while the manifolds are off. any reccomendations on plugs, coil, cap, wires. anythign else i shold be doing?
Old Nov 26, 2003 | 11:40 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
delco for plugs, taylor for wires.
cap and rotor i have had very little problem with so i can't really comment.
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
AC Delco Plugs, MSD or Moroso wires, MSD coil and MSD or Acell cap and rotor. Gap the plugs to .035's.
Use stage 8 locking header bolts and percy's aluminum header gaskets.
Kat
Old Nov 26, 2003 | 12:10 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
msd wires and coil... one note.. you might want to get the protector sleves for the wires b/c of the increased heat with the headers, dont want to go melting wires... i think they cose about 40 bucks or so. but beats wasting a good set a wires
Old Nov 26, 2003 | 12:11 PM
jpk91rs's Avatar
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
I agree with the AC Delco plugs. I agree with the Taylor wires. Any aftermarket distributor cap and rotor with the brass terminals and a MSD coil should do the trick.:rockon:
Old Nov 26, 2003 | 12:41 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
what are protector sleeves for the wires ?? should i get a set of wire looms for them or is that somethign else??
Old Nov 26, 2003 | 01:03 PM
bbtaz97's Avatar
Car: 91 RS
Protect your boots from the heat.
6 in. long, 1200 degree F, spark plug boot protector
These Taylor fiber-glass spark plug boot protectors withstand temperatures up to 1,200 degrees F.
Sold in packs of 8.
$52.95 at summit...
item # TAY-2524...
htese are what i have...
Old Nov 26, 2003 | 01:17 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
I use the Accel 300+ race plug wires. They're expensive, but they last a long time. As for plugs...AC Delco or even Autolite Copper Core. I currently have a set of NGK's in my Jeep, but they are there because that's what the parts store had on hand for my engine (AMC V8). I'll be switching them out to a set of AC Delco plugs when they finally go bad.
Old Nov 26, 2003 | 01:26 PM
Dewey316's Avatar
Car: 1990 Camaro RS
i suggest taylor wires, i have used the other, and the msd's and other seem to get britle after time, the taylors hold up like non of the others myself, or many others i know have used. the terminals seem to stand up to headers just fine, they are pretty heavy duty.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
